Re: Something borrowed...something FAST! [RChung]
Re: Something borrowed...something FAST! [eb]
no, i said it's possible, which means it also might not.
so in the real world you mean to tell me that Fabian Cancellara loses 2 minutes on his 40k tt if he simply swaps to the P2K frame? Ha, that's laughable!
Re: Something borrowed...something FAST! [donm]
Maybe it's not hard to imagine, but it's hard to make it fit the observations. The P2K CdA estimated during this test run is consistent with the value he has estimated both during other tests and during races, so he would've had to have been sitting up during every one of those tests, too, in order to get the level of repeatability he's shown.
Hmmm. Now you're going off the rails. Desperation can do that. Calm down.
Re: Something borrowed...something FAST! [sib1]
For example more reality........with a ~3 minute advantage, I'd expect some more (or maybe at least even 1?) P3C's !
Results - Stage 13 (Albi - Albi)
1. Alexandre Vinokourov (Kz), ASTANA, 1:06:34
2. Cadel Evans (Aus), PREDICTOR - LOTTO, 1:14
3. Andréas KlÖden (G), ASTANA, 1:39
4. Andrey Kashechkin (Kz), ASTANA, 1:44
5. Bradley Wiggins (GB), COFIDIS CREDIT PAR TELEPHONE, 2:14
6. Yaroslav Popovych (Ukr), DISCOVERY CHANNEL TEAM, 2:16
7. Alberto Contador (Sp), DISCOVERY CHANNEL TEAM, 2:18
8. Sylvain Chavanel (F), COFIDIS CREDIT PAR TELEPHONE, 2:38
9. Levi Leipheimer (USA), DISCOVERY CHANNEL TEAM, 2:39
10. Mikel Astarloza (Sp), EUSKALTEL - EUSKADI, 2:42
11. Michael Rasmussen (Dk), RABOBANK, 2:55
12. Vladimir Gusev (Rus), DISCOVERY CHANNEL TEAM, 2:56
13. Leif Hoste (B), PREDICTOR - LOTTO, 2:56
14. Linus Gerdemann (G), T-MOBILE TEAM, 3:09
15. Juan Manuel Manuel (Sp), QUICK STEP - INNERGETIC, 3:12
16. Juan Jose Cobo Acebo (Sp), SAUNIER DUVAL - PRODIR, 3:13
17. Vladimir Karpets (Rus), CAISSE D’EPARGNE, 3:17
18. Kim Kirchen (Lux), T-MOBILE TEAM, 3:18
19. Oscar Pereiro Sio (Sp), CAISSE D’EPARGNE, 3:23
20. David Millar (GB), SAUNIER DUVAL - PRODIR, 3:27
Check the prologue and the final TT, same thing, 1 or no P3C's........with that huge advantage, sorry but this theory isn't adding up.....
Likewise, if P3C is 2 min faster than P2K, then P2K is probably a good 3 min faster than round tube. And a round tube bike with the same geometry " ain't no " 5 minutes slower than a P3C no matter how you look at it!
BTW, if the laps are done at different speeds (as they were here) then wind also distorts the profiles. That's how we know that whatever wind there was must have been very, very small.
why?
if the power output is the same, conditions are the same, why not?
what experiment will it take to prove this out to you?
PI suggestion that if perhaps if tom found a 10k course that was dead flat, out and back, close to a weather station that would show that conditions remained the same (or dammit Tom you could get a kestrel) and made two runs at the same power (Pave~=Pnorm or VI=1.0) back to back and the difference was as predicted by the field testing (~30s) difference...
would you and FD believe?
would you believe that FC would loose 2 minutes in a 40k tt by switching to a p2k?
if not, then would the two of you PLEASE describe a proof that would satisfy you?
and barring that quit yer bitching?
because the "intellectual" part of the discussion is rapidly degrading....
g
greg
www.wattagetraining.com
Re: Something borrowed...something FAST! [gregclimbs]
g[/reply]
that's the argument, that there really isn't a "Proof" that would be totally accurate across the board. no doubt that it's and interesting study, but if the goal is to say a P3C is definitely 2min faster as a rule of thumb, then i think you're way off base with that type of assertion.
it's not that "intellectual" if you try to turn a one study opinion into fact, without considering all potential sides of the story, the likelyhood of flaws, and as well as trying to dis-prove the theory. now if we start talking multiple people doing the same test and get similar/same results, then we might be on to something.
if the claim is simply "it's faster for Tom A" then i'm totally on board with you.
g[/reply]
the current test done by Tom suggests such an explanation, but, in view of the largeness of the difference, the lack of the real world (racing) correlation suggests to me another explanation for the difference is at work.
Frank,
An original Ironman and the Inventor of PowerCranks
I don't think tom ever made a claim beyond that, BUT...
I would say the the refinded claim should read:
The p3c is significantly faster for tom vs. the generally acceptly fast p2k. And there does appear to be a strong correlation to the data of at least 2 other riders that suggest the difference is rider independant"
G
greg
Re: Something borrowed...something FAST! [Andrew Coggan]
The Trimble had a boxed-off area behind the "seatstays" which IMO would result in a large low-pressure zone there, and resulting high drag. I'd be willing to bet that the vortices spinning off the rider's legs interacted with that zone substantially. I remember looking at that bike (1990 Nats in Albany or 1991 at Tooele IIRC) and thinking "there's no way this thing can be aero".
FWIW, Eric
One more time: are you going to provide some evidence for your assertions?
Really, can't you see that this is getting tiresome? You trot out one unsupported statement after another, but you never provide any reasoning, any evidence, or any logic - just your unsubstantiated beliefs. If you want to argue about religion, fine, but maybe there's a better place for that.
Re: Something borrowed...something FAST! [Frank Day]
Even if you have that low pressure in the back, in a yaw condition, I would expect you get a benefit similar to a disc wheel.
"Likewise, if P3C is 2 min faster than P2K, then P2K is probably a good 3 min faster than round tube. And a round tube bike with the same geometry " ain't no " 5 minutes slower than a P3C no matter how you look at it!"
Yet again: are you going to provide some evidence for your assertions? Your first sentence above is a marvelously contorted logical absurdity. The second one I can accept as your opinion, sure, but again, it is your unsubstantiated belief and why on Earth should we care?
I really don't intend to pick on you ; there's at least one other poster on this thread who all my comments would apply to equally well. However, he has proven to be incorrigible and I was hoping you weren't. Having asked several times now for you to support your assertions, and having gotten only more of the same, I'm bowing out.
Anyway, perhaps you will be able to see why you're coming off as desperate when I explain why I'm not threatened at all: this isn't my study, observational or otherwise. You haven't made any argument except to point out the potential for procedural bias. The potential bias you're hanging you hat on is of unknown size but you're saying it invalidates any claim to difference.
I've been pointing out a difficulty in your argument: that the profiles in this test in conjunction with results from Tom's earlier tests put bounds on the size of a putative procedural bias. Those bounds are much smaller than the size of the effect estimated here.
So don't argue "the potential for bias is so huge it invalidates the results." You have to argue "the bias is so huge it invalidates the results." And, if you're going to stick to that argument, try to explain how the bias could be that huge and yetl be undetected by the data before us.
So don't argue "the potential for bias is so huge it invalidates the results." You have to argue "the bias is so huge it invalidates the results." And, if you're going to stick to that argument, try to explain how the bias could be that huge and yetl be undetected by the data before us.[/reply] Maybe I could accept this result if the pro tour teams were paying Cervelo to ride their bikes, instead of the other way around.
I don't know the actual size of the bias. I know it to be potentially large. If we can all agree that there is a potential bias and that no one knows how large it is then maybe we can all agree that it is unreasonable to argue that the totality of this result represents aerodynamic improvement attributable to the bike itself.
Frank,
So don't argue "the potential for bias is so huge it invalidates the results." You have to argue "the bias is so huge it invalidates the results." And, if you're going to stick to that argument, try to explain how the bias could be that huge and yetl be undetected by the data before us.[/reply] I still don't understand what your sentence meant. Whether it's the problematic grammar of your sentence or your misunderstanding of the term "threats to validity" I'm not sure, but it's beside the point.
I apologise for attributing this study to you. It's Tom's study, but my criticisms are of the study design which, if I understand right, is attributable to you. I actually think it's a good study design and, with the evidence presented, I'd be pretty confident that the P3C is a faster frame for Tom than the P2K. I don't think it's valid, though, based on the evidence presented, to suggest that you can estimate of the magnitude of difference attributable solely to the frame with much precision. I think a "2 seconds per km" or similar rule of thumb isn't well supported by the evidence presented.
Since you brought up reality, you should probably keep in mind that these are all different riders with different strengths, different fatique levels, and most importantly DIFFERENT GOALS (among many other things). These things will certainly bias the outcome. You see, aerodynamics isn't the only thing to consider when you are talking about a single stage in the pro tour, even if it's a TT.
I really wanted to thanks sib1 and donm for what they did in this thread. Through their clever questions and remarks, the truth surfaced at last, and now we know that this kind of testing, even if interesting, has too many faults and doesn't relate at all to the real world. Thanks guys.
Re: Something borrowed...something FAST! [Karl Rove]
that's just like you. Except for the interesting part.
[/reply]
Really, can't you see that this is getting tiresome? You trot out one unsupported statement after another, but you never provide any reasoning, any evidence, or any logic - just your unsubstantiated beliefs. If you want to argue about religion, fine, but maybe there's a better place for that.[/reply]
no, like i said before, think about it in the real world with real pro's. i'm asking you to think outside the scientific box for 2 seconds and see if that would hold up in reality. if you want to think that FC would lose 2 minutes by swapping a great frame for a good frame, then that's your problem. i think the real world pro results speak for themselves. figured up the ratio of guys on Cervelo's vs winners on Cervelo's, and it isn't too tough to see it doesn't add up!
