Hello All,
We have a patent pending product (and we will add it to the view-speed.com website before too long) that ONLY works at present with Speedplay pedals. The conversion will work with either Speedplay X or Speedplay Zero pedal/cleat systems. We recommend the newer Speedplay Zero system if you have a choice as it appears the cleat wears longer and is less prone to foreign material interference.
Race tested, wind tunnel tested, View-Speed Aero Shoe conversions are now available for $163.60 (ST discount $143.97) plus tax (if shipped to Calif) plus shipping and handling. You ship your race shoes to View-Speed, wait about 3 weeks, we ship them back, and the next time you put your race shoes on you will notice:
Safety – No groin pulls or falls when you stop, put your foot down, and your metal cleat slips on the pavement; with the soft rubber sole the shoe grips the pavement ….. also your wife will thank you for not scratching up the floors with your cleats.
Comfort – Little or no sound when walking (on soft rubber soles) and you will not pick up a lot of foreign material in your cleats when walking around – your cleats are protected. If you are a fore foot striker you can actually run in your shoes when you have the View-Speed Aero Shoe conversion.
Speed – About 40 seconds per hour faster (4 minutes for a 6 hr ride) ………… San Diego Low Speed Wind Tunnel tested.
The testing was done on a conventional 3 hole mount and performance should be even better with the new lower profile Speedplay 4 hole mount shoes like Bont and DMT.
Comparison of regular cleat and View-Speed Aero Shoe conversion with pedal inserted showing aero contours
The conversion works for most bicycle shoes and consists of adding a soft rubber sole in an aero configuration
Speedplay pedal extends considerably beyond cleat causing aero drag on non modified shoe
Pedal ‘retracted’ into opening and flushed up with bottom of View-Speed Aero Shoe conversion – similar to aircraft wheel retraction (note: the heel strike tab comes off for a race)
View showing pedal ‘retracted’ and flush causing very little aero drag with View-Speed Aero Shoe conversion
Please let me know if you have any questions.
Cheers,
Neal
+1 mph Faster
Cheers,
Neal
+1 mph Faster
