Sharing Golden Cheetah Between Machines
The goal of this email is to provide you a recipe for sharing ride files with your coach or another machine. The method uses Dropbox. The general idea is contained in the following diagram:
http://imgur.com/QhK6MhX
( Edit: wow, did that image file turn out crappy. I will fix it as soon as possible.)
Now let's assume you have a username "XXX" on your computer, and you've also made a cyclist named "XXX" in Golden Cheetah.
Windows 7 Recipe:
Athlete:
1. Install GC.
2. Create your athlete profile on it. Athlete->New
3. Close GC
4. Go to C:\Users\XXX\AppData\Local\GoldenCheetah . Drag the XXX folder into your Dropbox.
6. Create a symbolic link from the athlete folder in Dropbox into the old location where you moved it from. In a command prompt window, do the following (for example):
$ mklink /J C:\Users\XXX\appdata\local\GoldenCheetah\XXX C:\Users\XXX\Dropbox\XXX
7. Try going back into GC to see if it still works.
8. Share your Dropbox/XXX folder with your coach.
9. Use GC normally to import ride files. Go ahead, import one.
Coach:
- when the XXX folder appears in your Dropbox, repeat step 6 on your own machine
- check that the athlete now exists in GC
Mac OS X Recipe:
Athlete:
1. Install GC.
3. Close GC
4. Go to Library/GoldenCheetah . Drag the XXX folder into your Dropbox.
$ ln -s ~/Dropbox/XXX ~/Library/GoldenCheetah/XXX
Coach:
- when the XXX folder appears in your Dropbox, when the XXX folder appears in your Dropbox, repeat step 6 on your own machine
AndyF
http://alphamantis.com
#findyouraero
Re: Sharing Golden Cheetah Between Machines [AndyF] [ In reply to ]
Thanks Andy
this is actually exactly what I had done in the past.
BTW I also do it to share my Garmin "devices" directory onto Dropbox
What I found when using 2 Windows PCs is that if I changed on one machine, when I would startup GC on machine 2 it would want to refresh statistics, and doing so would crash.
Maybe I need to retry with latest builds
Do you think the trick will work cross platform ?, ie share data across a Windows and MAC machine
I do it using Google Drive and the latest development builds which allow you to change the user data location. Basically install a dev build and then (I only have Windows) click Tools - Options and change the Athlete Library to c:\users\username\Google Drive\GoldenCheetah and close GC. Copy in the athlete folder to that same folder and fire up GC. Do the same process on another computer and they will stay in sync.
That probably won't work as well in a coach/athlete scenario but it works great for me to have copies of the data on two computers.
Re: Sharing Golden Cheetah Between Machines [marcag] [ In reply to ]
marcag wrote:
Thanks Andy
This is the formula used on one of the national teams. They track a lot of riders, as you can imagine. I hope it does work. Let's make sure it does,
Yes, absolutely!
I'm on Linux here, and I have a rider who is entering her data on Windows 8. Easy peasy.
AndyF
#findyouraero
Here's another way to do it, just posted:
http://thebikegeek.blogspot.hk/2014/11/syncing-golden-cheetah-across-multiple.html
Cheers,
Tony
http://bike-energy-lab.com
