cmd111183 wrote:
Currently on a 2014 Blue Triad EX. Sram Force all the way around. Shimano Ultegra pedals. I really like the Shimano pedals a lot, although have to admit I've never tried Speedplays, but I digress. Wheels are 88mm Chinese Carbon Clinchers. Crankset is a Vision Trimax, not totally sure on length - 172.5 I think is standard on a 55 M/L? BB30.
I'd prefer not to have to have a wheel built with Power Tap unless that's the absolute best
That should make it easier for others to chime in. You should read the DC RAINMAKER that I linked to. When you say you want "the best", SRM may still be considered to be the "gold-standard" (Ray's words) of power meters, but as Ray says, he can't justify spending that much money on a product that may not be any better than other spider-based PMs at this point.
If you feel that you need true left/right balance measurements, which you probably don't, then Garmin Vectors may be best for you. If you're comfortable doing an install yourself, then Power2Max is an excellent option. If you want to order something through your LBS and have them install it, then one of the Quarq options may make sense. I haven't looked into Stages or 4IIII, but they may be good solutions.
One of the things that I like about the spider-based PMs, is that I can affordably swap out my OEM cranks for shorter cranks, which is something I want to do. If you're happy with your 172.5 mm cranks, then maybe something like Stages would be more cost effective.
If you haven't read any books yet on the subject, maybe you should do that before purchasing a PM. I'm glad I read this:
http://smile.amazon.com/...p;smid=ATVPDKIKX0DER
