Bike Shops
Coaches
Fitters
Race Calendar
Running Stores
Store
Stack & Reach
Training Log
Triathlon Clubs
We Noticed
MAIN INDEX
RULES & LEGEND
LOG IN
Slowtwitch Forums
S5 as a TT bike - first cut
1
2
3
4
5
6
View All
Tri
Classifieds
Lavender
Jobs
Womens
Notices
Print Thread
Tom A.
Feb 4, 12 19:53
Post #26 of 129
(5789 views)
Re: S5 as a TT bike - first cut [Der_Kaiser]
In reply to
Quote
Reply
Der_Kaiser wrote:
Not a personal attack, but that bike is simply fugly.
Fast is "pretty" to me :-)
tigerpaws
Feb 5, 12 4:55
Post #27 of 129
(5692 views)
Re: S5 as a TT bike - first cut [Tom A.]
In reply to
Quote
Reply
Tom A. wrote:
As long as the cable inner ends are clean (I'll put a drop of superglue on them to keep them from unraveling)
CRAP! I did cockpit swaps with the same methodology on my Tachyon back when they made them with slacker geo. I put electrical tape on the ends which worked about 5% of the time and I almost always had to re-cable. What makes it even more maddening is that Super Glue is part of my
Man Card Go Kit
along with duct tape and zip ties....it was right in front of me! Giving myself 7 demerits for not knowing this trick. OH well it's only 20 years late;)
Hope the sniffles are
just
the sniffles, rip hard today.
(This post was
edited
by tigerpaws on Feb 5, 12 4:56)
Barchettaman
Feb 5, 12 5:38
Post #28 of 129
(5658 views)
In reply to
Quote
Reply
Love these dual-purpose builds.
Thanks for posting, Tom. Best of luck in your TT.
.....for the retail cost of a single set of 404 FCs ($2,725) you can get a Flo 60 Front, Flo 60 Rear, Flo 90 Front, Flo 90 Rear, and a Flo Disc (total: $2,395) and still have money left over to buy Continental GP4000s for the whole lineup.
(Aerogeeks)
mopdahl
Feb 5, 12 7:26
Post #29 of 129
(5573 views)
In reply to
Quote
Reply
I figured out what was fugly about the bike---the Adamo---it just isn't "elegant" & magnifies the "blockiness" of the bike. Then again I ride a SMP which is pretty high in the weird category.
Attractive road setup. How do you like those brakes (performance wise, not just their aeroness)?
Good luck today.
____________
“There are two novels that can change a bookish fourteen-year old’s life: The Lord of the Rings and Atlas Shrugged. One is a childish fantasy that often engenders a lifelong obsession with its unbelievable heroes, leading to an emotionally stunted, socially crippled adulthood, unable to deal with the real world. The other, of course, involves orcs.” John Rogers
Tom A.
Feb 5, 12 7:48
Post #30 of 129
(5546 views)
Re: S5 as a TT bike - first cut [tigerpaws]
In reply to
Quote
Reply
Man Card Go Kit
Well, the superglue trick isn't 100% either (but better than 5%!)...sometimes the difficulty with re-using the cables is from where the clamp points deform it anyway. I just make sure I have some spare fresh cables handy if I'm going to do the swap so if one starts giving me fits, I just throw in a new inner.
just
Unfortunately, the head cold
did
get worse overnight...so I pulled the plug at about 5am this morning. It wasn't surprising since my entire family seems to have the exact same thing all at once. I'm sitting here now with a nice steaming mug of coffee "soothing" the back of my throat, so no hard ripping is on the agenda today :-(
Tom A.
Feb 5, 12 7:52
Post #31 of 129
(5535 views)
In reply to
Quote
Reply
Well, as I commented once to someone else about the "looks" of the Adamo, "My nether regions don't care one bit about your aesthetic sensibilities" ;-)
The brakes work great. My only complaints about them are that if you use wheels of varying widths, they aren't the easiest to center and adjust spacing...and it can sometimes be difficult to thread the end of a cable through the clamp hole, especially if it's been cut previously. Other than that, they are good performers.
SeasonsChange
Feb 5, 12 7:54
Post #32 of 129
(5534 views)
In reply to
Quote
Reply
The real question is what is your cda now. <0.20!?
JollyRogers
Feb 5, 12 8:02
Post #33 of 129
(5517 views)
In reply to
Quote
Reply
Tom A. wrote:
Can't see much of the saddle while the bike is being ridden either; though I guess more of the Adamo is visible than most saddles.
Tom A.
Feb 5, 12 8:12
Post #34 of 129
(5492 views)
Re: S5 as a TT bike - first cut [SeasonsChange]
In reply to
Quote
Reply
That remains to be seen...
BrianB
Feb 5, 12 8:29
Post #35 of 129
(5463 views)
In reply to
Quote
Reply
To me it's not the saddle. It's how the seat tube is so much bigger than the seat post. I think if the post were wider, to match the seat tube, it wouldn't look so "blocky". But I'm guessing they can't do that and be within the UCI 3:1 aspect ratio.
styrrell
Feb 5, 12 8:34
Post #36 of 129
(5454 views)
Re: S5 as a TT bike - first cut [BrianB]
In reply to
Quote
Reply
I'm sure what you suggest could be done, but a smaller airfoil of the same shape has less wind resistance than a bigger one. Same with the newest cannondale. The seat post looks bad but a small post is all that is needed structurally so adding material for looks is bad. Especially with a seat post at some point it stops cutting through the air and starts pushing the air out to your thighs.
Styrrell
jmh
Feb 5, 12 9:55
Post #37 of 129
(5402 views)
In reply to
Quote
Reply
It looks like the road version has SRAM and the TT has Shimano rear mech and shifters. Was this conversion more than just bars and cables?
Also tell more more about that new Quarq crankset.
Tom A.
Feb 5, 12 10:32
Post #38 of 129
(5380 views)
Re: S5 as a TT bike - first cut [jmh]
In reply to
Quote
Reply
Good eye. I had sold my SRAM TT shifters with my Transition and the 100K bars still had the Shimano bar ends installed from the last time I had used them. I figured for this trial run I could just use the Shimano shifters in friction mode with the SRAM rear derailleur...which is all well and good except for the fact that the Shimano bar end doesn't have enough total travel to be able to shift up the entire cassette with the SRAM derailleur. Doh! Luckily, I had a spare Shimano derailleur I could throw on there and I'm using a chain with an easily unlatched master link ;-)
I plan to acquire some more SRAM TT shifters soon.
It's a prototype version of the "Red" CinQo.
realAlbertan
Feb 6, 12 20:28
Post #39 of 129
(5140 views)
In reply to
Quote
Reply
|I thought aero bottles were now banned by the UCI?
http://en.wikipedia.org/...eoesophageal_fistula
http://en.wikipedia.org/wiki/Cerebral_palsy
Canadian Record Holder 35-39M - 1500 metre Freestyle
jackmott
Feb 6, 12 20:30
Post #40 of 129
(5132 views)
Re: S5 as a TT bike - first cut [realAlbertan]
In reply to
Quote
Reply
not entirely, their dimensions are just now more regulated
and tom doesn't race uci races
Meet Pro Triathlete Matty Reed at ATC - Sat May 25 - Captex!
The newest tri shop in Austin - ATC 360
Mr Faded Glory
Feb 7, 12 3:15
Post #41 of 129
(4998 views)
Re: S5 as a TT bike - first cut [jackmott]
In reply to
Quote
Reply
Can you please post a link to that information?
Dopers.Suck
Feb 7, 12 4:46
Post #42 of 129
(4938 views)
In reply to
Quote
Reply
They are not banned until Jan 2013. They must be no more than 10cm in diameter and hold between 400ml and 800ml, they also must be located in the main triangle of the bike with a gap between bottle and frame. Very ridiculous!!!
"I swim because that's how I get to ride my bike."
Ryon
Feb 8, 12 12:53
Post #43 of 129
(4730 views)
In reply to
Quote
Reply
yeah, you know what looks reeeeealy awesome? Your name at the top of the results in a TT. Velocity > Vanity. (though I think it looks pretty nice myself)
My Cancer Q&A Blog
"The only fair race is the race against the clock" -Anquetil
Tom A.
Feb 8, 12 12:57
Post #44 of 129
(4709 views)
Re: S5 as a TT bike - first cut [Ryon]
In reply to
Quote
Reply
Do you mean sort of like the Cat 3 results here?
http://www.fiestaisland.com/.../01feb05/results.htm
Ryon
Feb 8, 12 14:47
Post #45 of 129
(4573 views)
In reply to
Quote
Reply
Haha. Well, I want to get the fastest overall time now. Time to start speed training...
Oh, and you'd be proud of me. Lowest CdA I've ever recorded. That's sort of like a PR in itself!
My Cancer Q&A Blog
Tom A.
Feb 8, 12 15:13
Post #46 of 129
(4532 views)
In reply to
Quote
Reply
There's no "sort of" about it at all ;-)
drgwood
Feb 17, 12 6:23
Post #47 of 129
(4266 views)
In reply to
Quote
Reply
Tom
I was hoping to get your opinion based on your experiences with the S5 set up as TT bike.
My bike was recently totaled by a car (with me unfortunately on it). I have healed but I am without TT bike at moment
I have buddy who will lend me a P3 (previously on P4) and I have a S5 on order.
Was wondering based on your recent experiences do you think the S5 set up as TT bike would be faster than the P3?
I can get to the same position with an adjustable stem on S5 so all else should be relatively equal between the two.
thanks
rob
TH3_FRB
Feb 17, 12 7:35
Post #48 of 129
(4181 views)
In reply to
Quote
Reply
Power2max
Tom A. wrote:
I didn't swap the cranks as part of this TT buildup. Those had been changed a few weeks ago. I can't tell you much about the crank, but if you look closely you might be able to decipher what it might be ;-)
Thanks!
Sisu Multisport & Endurance
Sisu Multisport & Endurance on Facebook
My blog -
ON-ON (to Kona?)
Tom A.
Feb 17, 12 7:40
Post #49 of 129
(4169 views)
Re: S5 as a TT bike - first cut [TH3_FRB]
In reply to
Quote
Reply
TH3_FRB wrote:
Power2max
Thanks!
Ewwww...no. I prefer power meters that don't have offset values that drift "willy-nilly" ;-)
Tom A.
Feb 17, 12 7:45
Post #50 of 129
(4154 views)
Re: S5 as a TT bike - first cut [drgwood]
In reply to
Quote
Reply
drgwood wrote:
Tom
thanks
rob
With equivalent positions and equipment, yes, I've been told it
should
be faster than a P3...I haven't confirmed that (yet) though ;-)
1
2
3
4
5
6
View All
Print Thread
this forum
this category
all forums
All words
Any words
Whole Phrase
Market Influence
What influences your swim/bike/run product buying decisions most? The use of products by, or comments made by or in:
Pro cyclists?
Pro triathletes?
My non-Slowtwitcher friends?
Forum members and other Slowtwitchers?
Slowtwitch tech articles and forum moderators?
Other magazines?
Manufacturers?
My LBS?
Ratings/comments on other websites?
Other
