LSUfan4444 wrote:
I considered this option for IMCHOO, but in the end it just wasn't worth it. I looked at the Castelli T1: Stealth which claims a 3 minute advantage in wind tunnel testing over a 5 hour IM course. So, if they are publicizing it, that is best case scenario. That means perfect fit. TIGHT! With no wrinkles.
So I've got to put a skin tight top on with wet arms and assuming I get it on with no lost time whatsoever and my fit is ideal, the best I can save is 3:00? No thanks. What if it takes me longer than three minutes as I struggle with wet arms? Now, I've just spent $150 to be slower.
I know sleeved tops are the rage right now, but most of the one I have seen aren't even close to fitting right. So while I encourage others in M 40-44 to get them, I just don't see the benefit in regards to cost/risk.
I have done it 3 times now. Twice with the Pearlizumi and once with the Garneau. The Pearlizumi is much harder to get on and I did feel like I might tear the suit; however, I never did. I promise you that it will not take 3 minutes. That is silly. It took me about 10-15 seconds to pull it on in transition without ever having practiced it. I am sure that you could practice doing it on the run out of swim exit and lose zero time.
Let me emphasize I never practiced this. I just rolled the suit into my swim skin. Did the swim. Unzipped my swim skin. Pulled the top up. Both suits fit skin tight with no wrinkles. In fact when I put them on I feel like a sausage in a casing that is 2 sizes too small.
If you are in my age group, don't do it. It is completely impossible and not worth the time savings.
