MAIN INDEX RULES & LEGEND LOG IN
Slowtwitch Forums: Triathlon Forum:
Reynolds Strike w Disc Cover
Coasterx
May 18, 11 11:30
Post #1 of 12 (1541 views)
Reynolds Strike w Disc Cover Quote | Reply
Has anyone actually seen/put a Reynolds Strike with Disc Cover? Have you seen one the fits proper without a silly gap?
Recommendations?
WB does not list Reynolds strike in the 'predefined' wheel list so I am hesitant to measure and end up with something that doesn't fit right.
Suggestions?
wasfast
May 18, 11 13:38
Post #2 of 12 (1501 views)
Re: Reynolds Strike w Disc Cover [Coasterx] [In reply to] Quote | Reply
I bought one from wheelbuilder for my Strikes and it fit fine. If I did it again, I'd completely skip the plastic bolts and the drilling for them. Tape the perimeter and you're all set.
Frenchman
May 18, 11 13:44
Post #3 of 12 (1495 views)
I got one and it worked fine once I sanded the drive-side hole to make it slightly larger so it would fit well with the cassette.
DV1
May 18, 11 14:53
Post #4 of 12 (1456 views)
I called WB a few weeks ago about this exact setup fit question and they indicated they had built "many" with "no issues" for strikes.
DV1
May 18, 11 14:55
Post #5 of 12 (1455 views)
Re: Reynolds Strike w Disc Cover [wasfast] [In reply to] Quote | Reply
Could you elaborate? You'd really trust just tape?
wasfast
May 20, 11 7:04
Post #6 of 12 (1356 views)
Re: Reynolds Strike w Disc Cover [DV1] [In reply to] Quote | Reply
The plastic bolts don't really secure the cover all that much and the lip tends to not sit perfectly flat against the rim. Myself and others use a single layer of electrical tape to seal the edge. My only caution with electrical tape specifically is that the adhesive is very heat sensitive and can become gummy and soft in the heat. You can find other posts via the search where folks only used tape and no fasteners.
jackmott
May 20, 11 7:07
Post #7 of 12 (1353 views)
I've been using just tape on my wife's wheel and my wheel for 2 years now. No problems.
there are a couple advantages:
1. tape actually holds the cover still, no movement up/down over bumps, which makes it quieter than the bolts, and makes the cover last long (tends to crack around the center hole otherwise)
2. its probably hair splittingly more aero with tape
if you use good quality 3m tape, and clean both surfaces before hand, it absolutely holds it on strongly.
check the tape before each race, no problems.
the extra cautious can use the plastic bolts AND tape to get the first benefit still.
Memorial day sale at ATC and Meet Pro Triathlete Matty Reed - Sat May 25 - Captex!
The newest tri shop in Austin - ATC 360
Bypasskid
Jul 18, 12 8:48
Post #8 of 12 (685 views)
Re: Reynolds Strike w Disc Cover [jackmott] [In reply to] Quote | Reply
You still need to take the cassette off right?
___________________________________
Nothing tastes as good as skinny feels
Karl
Jul 18, 12 8:58
Post #9 of 12 (675 views)
Re: Reynolds Strike w Disc Cover [Bypasskid] [In reply to] Quote | Reply
Yes, cassette must come off. I use the tape method- no plastic bolts- and think it works much better. I add some packing tape to the inside drive side to hold it in place before the electrical tape.
EricB
Jul 18, 12 9:10
Post #10 of 12 (664 views)
Re: Reynolds Strike w Disc Cover [Karl] [In reply to] Quote | Reply
I first used just the screws to hold mine onto my Strikes and the covers rubbed scrapes into the wheels after a very short time from moving slightly back and forth. My biggest suggestion is to spend the extra few dollars and get a really good quality 3M tape. It works wonders, no need for the screws at all. It also completely stops the cover from moving therefore scratching the wheels. Best of Luck
E
Max Daddy
Jul 18, 12 10:07
Post #11 of 12 (633 views)
Re: Reynolds Strike w Disc Cover [EricB] [In reply to] Quote | Reply
I put electrical tape around the perimeter where the cover will sit first. Then tape the cover to that. This prevents the scraping on the wheel. Plus it gives my OCD butt more to obsess over.
rbuike
Jul 18, 12 12:25
Post #12 of 12 (598 views)
Wheelbuilder sells Reynolds wheels and they make the cover. I ordered one with my wheels, fits perfect! And as the rest have stated, tape the cover on, don't bother with the fasteners.
Rodney
TrainingPeaks Ambassador
ICEcot Athlete | Team Vega Athlete
http://barefoottriathlete.ca
The New Specialized Wind Tunnel
Will this be a game changer for Specialized, in both sales and product design, or will it not move the sales and design needle versus those in Specialized's competitive set?
Yes, Game Changer
Minor move forward
Won't budge the needle
