I will give a one time reply here and copy it to the other thread. Not interested in a long debate regarding the outcome.
First, if I was internet fitting, I would certainly agree that the cockpit was a bit short, and I would speculate that if I got my hands on this rider, I could get him stretched out a bit. I would not however think that this result was incorrect nor outside the realm of possible positions that a proper fit could produce. hence the danger if internet fitting.
However, I was doing an actual fit on modern equipment, and using years of experience to elicit excellent feedback from the rider. As per the FIST protocol, you pretty much get what you want in regards to cockpit distance. That is not to say we didn't spend a good bit of time on that cockpit distance. In fact, we started out quite long (again, rider choice) and gradually brought it closer and closer. I went back to cockpit distance while changing the drop, after changing the setback, after angling the extensions, and even after shortening the crank. Each trial yielded a tighter cockpit.
After everything else was finalized, we went back one more time to see if a slightly longer reach was more comfortable. It was not, so we were done. This is not a masterpiece, I didn't create a work of art. I did give this athlete a solid fit. We definitely tuned in to a good bit of his bike fit DNA. Will he choose a longer cockpit on the future? Maybe, but he didn't yesterday.
Finally, I always take into consideration how a fit might change in the future when recommending bikes or simply discussing the results. In this case, I am almost certain the rider will never choose to be tighter, and pretty sure we squeezed about all the drop out of him that we can achieve without a loss in pedaling ability.
As far as Slowman assessing my fit as "pretty good", I'll take it. Maybe he has more to say, maybe not. One time he did a similar pretty good fit on a certain pro triathlete.
