Results from Speedplay Zero Aero Test
I'll keep this as short as possible. As the title suggests, we independently tested the Speedplay Zero Aero pedal against a standard Speedplay Zero pedal and did find a repeatable aero advantage. Here's a quick synopsis:
We used two test riders:
  • Male using Sidi Wire SP Carbon shoes (Speedplay-specific) who completed 3 runs with each pedal system
    • CdA w/Zero pedals: .2441, .2437, .2458 - Average CdA = .2445
    • CdA w/Zero Aero pedals: .2387, .2381, .2394 - Average = .2387
    • Watts Saved = 4.8
  • Male using Specialized S-Works 6 shoes who completed 2 runs with each pedal system
    • CdA w/Zero pedals: .2389, .2390 - Average = .2389
    • CdA w/Zero Aero pedals: .2352, .2359 - Average = .2355
    • Watts saved = 2.9
Both riders saw an aero advantage with the Zero Aero pedal, though rider #1 clearly saw better savings. There were two distinct differences between the riders which could provide an explanation. Rider #1 used a Speedplay-specific shoe which negates the need for a base plate thereby lowering the overall stack height of the pedal system reducing frontal area. Rider #1 also pedaled with a flatter pedal stroke (heal down) which exposes more of the pedal system to the wind. Rider #2 pedaled more toe down exposing less of the pedal system to the wind.
Testing one pedal system vs another (i.e. Speedplay vs Look) is a decidedly more difficult task, but could be done in the future. Questions?
Jim Manton / ERO Sports
Re: Results from Speedplay Zero Aero Test [Jim@EROsports] [ In reply to ]
Watts saved suggests there was a 'total watts' that was reduced through the use of the pedals. What is the percentage savings, and what is the margin of error for the test?
you left out detail....
did they both use the aero cleat on both runs or normal zero cleat both runs or switch cleats between runs?
    • Watts Saved = 4.8
    • Watts saved = 2.9
Thanks for the info. I hope you can test a Look system in the future.
Was seat height adjusted for both riders after changing pedals systems?
Chicago Cubs - 2016 WORLD SERIES Champions!!!!
"If ever the time should come, when vain and aspiring men shall possess the highest seats in government, our country will stand in need of its experienced patriots to prevent its ruin." - Samuel Adams
Nice test, nice insight.
Re: Results from Speedplay Zero Aero Test [Power13] [ In reply to ]
they are the same system
Nice.
What would be interesting to me is an additional data point with the speedplay specific shoe with the "walkable cleat" (i.e. the aero cleat) and the regular zero pedals.
In other words, how much of the improvement over the regular Zero setup is in the cleat and how much is the one-sided aero pedal? My gut feel is it's mostly the cleat "fairing"...and just buying the cleats is a MUCH less expensive proposition than the full aero pedal kit. And the reason I say on the speedplay specific shoe is because it appears the only way to get the aerodynamically shaped cleat spacer is by buying the aero pedal :-/
Re: Results from Speedplay Zero Aero Test [M----n] [ In reply to ]
His post actually included the base CdAs and the deltas, so you can derive the answers to your questions.
Re: Results from Speedplay Zero Aero Test [Tom A.] [ In reply to ]
Interestingly, when I was working with Brandon McNulty in prep for TT Worlds, we did test walkable cleats vs standard cleats on the Zero Aero pedal. We didn't have regular Zero pedals that day, so I figured I try it since I knew Brandon could give me good, consistent, numbers. We only did one quick test, but there was about a 1.5 watt difference. I don't like quoting one test, so I didn't include those numbers.
Test 2 gels with the CFD analysis AeroCoach did.
https://www.facebook.com/...sts/1098380433529928
also, what speed are you basing your watts saved upon?
at 30mph I get 8.5w and 5w if you want to bring up to frame/wheel equivalents
As jeffp indicated, there was no need since the riders didn't switch shoes. According to Speedplay, there is no stack height difference between the standard Zero cleat and the walkable cleat.
Re: Results from Speedplay Zero Aero Test [jeffp] [ In reply to ]
Both riders, by coincidence only, rode right around 24.5 mph if I remember correctly.
Missed this one...sorry.
For rider #1, the order of runs was: Zero, Zero Aero, Zero, Zero, Aero Zero, Aero Zero.
For rider #2, the order of runs was: Aero Zero, Zero, Zero, Aero Zero
Re: Results from Speedplay Zero Aero Test [Grill] [ In reply to ]
can't tell from that post if that was shoe moving in circular motion in the CFD or just sitting still in wind
I meant was it always with the aero-walkable cleat on all runs or did that vary too?
Oh, sorry Jeff. Cleats were changed, too. Standard Zero cleats on Zero pedals; walkable cleats on Zero Aero. The beauty of Speedplay is we could be reasonably sure to replicate the cleat/foot position. Tougher to do when comparing one pedal system vs another, which is why we didn't do it (or, at least, not yet).
I don't have specific data other than to note I am a tad faster since I switched to the aero system myself. just miss the two sided entry with that
What style shoe, i.e. did it have a spacer? And if so, what kind.
Also, that's not quite what I was getting at since the pedal is the Aero...I'm interested in how the walkable/aero cleat performs on the regular Zero pedal :-)
Pretty sure the CFD was done static with the total savings based on all moving parts extrapolated.
Well, duh....I'm a dyot. Didn't look carefully enough at what was tested.
Can't recall at the moment what shoe it was or if was Speedplay-specific or not. I know it wasn't exactly what you were referring to, but thought you'd be interested anyway.
I would like to know if you good 'guesstimate' the savings on an ironman leg 2.9 watts (lets say 3) and 4.8 watts. :)
"see the world as it is not as you want it to be"
Hello Jim@EROsports and All,
I will make a pair of these (the aero mod shoe on the left) available to you if you want to test them ..... they tested very aero for us at SDLSWT and you can even run on them for short distances ...... (and they have soft soles that are silent to walk on) ......
http://www.shop.view-speed.com/...ion-610098715986.htm
And they work with standard double sided pedal ....
Cheers, Neal
+1 mph Faster
