davews09 wrote:
I am looking for a pair of running gloves good down to about 15-20 degrees. All my pairs either freeze in the fingers with my sweat (don't wick away moisture) or just aren't warm enough. Would also be great if they were easy to take on and off while running...in other words, they aren't tight and/or impossible to get on when damp. Those things on the fingers to be able to use a touch screen would be a plus.
Thanks
If your hands are sweating then freezing bc they are wet, wouldn't you want a thinner glove? I use a pair of really cheap thin wool gloves down into the teens. They keep my hands warm enough, not toasty and sweating, but not too cold either.
I thought the rule on winter survival was not to work so hard you sweat. Then your clothes get wet and you can't keep warm. So as you warm up you shed layers to regulate body temp. Same with running gloves?
Team Zoot - Great Lakes
