rruff,
totally agreed with you on actually knowing what the tension is, but i have a problem buying a tool i'll only use once or twice(i'm cheap and i want quality tools.)
i've been trolling ebay for one of these:
http://www.ebay.com/...e=STRK%3AMEBIDX%3AIT but $255 isn't in my budget right now. i'm not sure i'd trust the cheap $65 Park one, but it's probably better than just winging it.
i also have been waiting for a wheelsmith tensiometer, but i haven't seen one available in the months before all the parts arrived.
as for the construction of the rim, the fairing is structural and the spoke-bed seems pretty strong. the exterior surface is smooth and free of imperfections;
the carbon layup looks consistent with no obvious flaws, folds or anything weird. the bond joint is clean and smooth too.
the alloy tire-bed/braking surface seems a little softer than the alloy used on my flashpoints(there are one or two tiny dents), but not so soft as to worry about it.
the sides are pretty straight and the 'head' edge is u-shaped. here's what they sent me:
i bought Shraners book and downloaded another wheel-building guide, and it seemed like it went ok for a first-ever build.
i had felt/strummed/listened to a wheel built by one of my LBSs that was supposed to be at 150 and built to slightly less than that(real precise i know.)
i was not comfortable enough to consider triplet/crows-foot going from 32 to 24, so that's why i ordered the 32h drilling.
rruff wrote:
i rebuilt my 32h powertap pro+ this past winter with this:
http://www.ebay.com/itm/one-pc-80mm-carbon-fiber-racing-bike-rim-aluminum-brake-surface-700C-23mm-width-/251893348441?pt=LH_DefaultDomain_0&hash=item3aa6037859
I'm curious about that rim. Is it a fairing like Flo, Hed Jet, and Swiss Side, or is it structural like the Flashpoints?
Also the shape. Is it 23mm at the brake tracks? Does it get any wider than that?
BTW, you could have laced your 24h Flashpoint rim triplet. Not ideal but possible. And your LBS guys are hacks if they don't use a tensiometer. You can get fairly even tension by ear and feel, but you still won't know what the tension is.
"...I try not to ever ride as slow as 20mph. ;) ... And even more than that, I don't race with a speedometer. My computer is set up to show Power // Cadence // Time. I don't actually ever know how fast I'm going. I only know that if I'm in 53/11, and it takes more than 100rpm to hit my target watts, it's time to coast." - Jordan Rapp on '09 IMC
