I have a 2017 SL5 Tarmac ETAP (chameleon paint) that I have an issue with. I installed a Quarq DZero power meter and have chain rub whenever I'm in the 34 up front (smallest up front) and 28T (largest out back, to the left) in the back. The limit screw is backed out all the way.
I have checked the following:
-check chainline with no spacers to be around 49mm.
-confirmed I have the correct crankset; quarq dzero
-confirmed I have correct 11 speed SRAM Red Yaw hidden bolt chainrings
-confirmed carbon seat-tube or braze on adaptor is free of debris
-confirmed no structural issues to the frame
-confirmed the FD cage is not bent
-confirmed crankset torqued to specifications
-confirmed chainrings installed correctly
-confirmed chain size for 11 speed
-I’m sure I’ve missed something.
I should note that with TWO nondrive side spacers installed to the drive side, the chain does not rub. Anyone have any ideas? I've emailed SRAM and Specialized both and they haven't responded yet
Confused Fitness Addict -- Biker first, Nutrition second, everything else third.
