I've only been riding seriously for a couple of years now, and my knowledge of my bike's maintenance needs must improve. Specifically, I'm now finding parts that have corroded or been damaged through neglect, but I didn't know I had to take protective measures in the first place.
For instance, I bent my 9-month old rear Bontrager wheel in a crash. When I took it to the shop to be trued, it turned out that the nipples had corroded (salt air) to the point of crumbling, and a rebuild was recommended. I was told that I should have been placing oil on the nipples to prevent the corrosion, but I had no idea of the need for such a thing. I had assumed that nipples were made of corrosion-resistant material. I was wrong, at least in Bontrager's case.
Also, the leading edge of my Trek carbon fiber fork has begun to develop chips in the finish. How do I deal with this problem? Is this the beginning of the end for my fork? Is there anything I could have done to prevent this issue from arising?
Are there any other not-so-obvious maintenance needs that you suggest paying attention to?
Any help is greatly appreciated. Thanks.
"The whole problem with the world is that fools and fanatics are always so certain of themselves, but wiser people so full of doubts." -- Bertrand Russell
