Has anyone installed (or use) the profile design Aeria 2 set up with Magura brakes. LBS is waiting on a call back but the brakes are not sliding into the base bar. Base bar measures 19.25 mm and Magura brakes are 19.5mm
Re: Profile Design Aeria 2 and Magura Brakes - don't fit [NeverEnough]
Wondering if if has to do with the non flexible barb bottoming out at the upturn of the bar (if that makes sense from my description). No reason the plug shouldn't fit I wouldn't think.
Re: Profile Design Aeria 2 and Magura Brakes - don't fit [zachboring]
zachboring wrote:
Wondering if if has to do with the non flexible barb bottoming out at the upturn of the bar (if that makes sense from my description). No reason the plug shouldn't fit I wouldn't think.It's the actually opening, upturn peice wouldn't be an issue if they fit in the base bar.
For anyone interested....they won't fit. Don't order if you are running Magura levers.
Wow, that's Crazy. First bar I have heard of like that. Do profile bars all have special requirements?
Now that I think about it, most compression plugs have a much wider range of diameter adjustment compared to the magura. Magura is very "fixed" in that sense.
zachboring: Mar 27, 15 10:26
any idea if that would be the case for a Svetzero and Svet R bar?
What is the difference (besides cost) between the Aeria and a svet basebar +extensions?
Does anyone know if the magura fit the zipp stealth vuka base?
