rmt wrote:
Garmin 510 collects them and they are available to view in Garmin Connect/WKO4. At present, however, the GPA/GPR function is doing some weird stuff and providing some very strange numbers!
Can you explain what you mean? GPA, GPR, KI, and MEPF are built-in functions, so either your build of the program is somehow munged, or the raw data aren't correct.
EDIT: Upon review, I bet I know what's going on. You're looking at the mean maximal GPR and GPA chart that Hunter created. The problem with that way of analyzing the data is that outliers generated by your powermeter will skew the curve (lots of funky stuff tends to happen at short durations, especially with dual-sided systems).
Instead, I'd recommend that you use a line chart (i.e., GPR, etc., plotted against time) or the Zorro chart to analyze your pedaling. That way the occasional bogus value will be immediately evident, and you can either mentally ignore such points, or rescale the axes (Y or
X - yes, you can do that in WKO4) to exclude them and focus on the valid data.
