So Im looking for a little advice.
I currently have a 105 5800 compact crankset. I was originally going to go with a 4iiii single arm power meter (cost constraints). Then I came across the power2max NG Eco and I thought to myself "dang! dual sided for 515 after shipping with a FSA Gossamer crank!(24mm axle)" SO I ended up ordering it. I get it today and pull out the crank. It feels like a boat anchor! So here are my thoughts...
Do I Keep the power2max?
Pros:
dual sided
lots of good reviews and feedback
Cons:
Boat Anchor crankset that seems to be non-existent on upgradability to a lighter crank down the road.
I have a set of praxis rings, but I would need a new chain because my 105 is compact and Praxis is not.
Praxis also doesn't seem to shift as well as the 105 chain rings?
Or do I return the Power2Max
4iiii
Pros:
Simple to just install the arm(though installing the power2max isn't much harder)
Get to keep my lighter crank
Better shifting with 105 crankset?(it seems to be smoother, but I could be crazy)
Cons:
Single Sided
Any advice is appreciated. Maybe even a few words of wisdom? Am I overthinking this?
-Brian
Pros:
dual sided
Cons:
4iiii
Pros:
Cons:
Single Sided
-Brian
