Hi All,
I had a 'Frame Finder Fit' from Guru at the weekend and have been presented with a number of options from the fit (It was basically a full fit to find the bike and when i've bought one, they'll fit me as per it)
Some of the suggestions are a bit odd IMO, particularly in some suggestions of stem length/angle combined with pad spacers....
From the below, to me it suggests that the best options are the BMC, Quintana Roo or Shiv - but is it safe to assume that all are perfectly fine. 120mm stems seem quite long but i'm new to tri bikes!
Trek SC, Size L: Stem Length 120mm, Stem Angle -6, Pad Spacers 55mm
Felt IA, Size 56: Stem Length 120mm, Stem Angle -6, Pad Spacers 45mm
Scott Plasma 20: Size 56: Stem Length 120mm, Stem Angle -6, Pad Spacers 50mm
BMC TM02, Size L: Stem Length 100mm, Stem Angle -17, Pad Spacers 55mm
Canyon Speedmax, Size L: Stem Length 80mm, Stem Angle +6, Pad Spacers 50mm
Quintana Roo PRFive, Size 56: Stem Length 100mm, Stem Angle -6, Pad Spacers 35mm
Shiv, Size L: Stem Length 110mm, Stem Angle -6, Pad Spacers 30mm
Cheers
http://www.tritriagain.uk
Cheers
