Found this thread when the fabric covering on my stock pads started peeling off (first photo). It's a bit worse on the right than the left -- probably something to do with my tendency to shrug the right shoulder. Decided to try the CeeGees and ordered them 2017-08-16, shipped from Spokane, WA on 2017-08-18 and arrived 2017-08-21 (in CA). The site must have been redesigned, because it was easy to find:
Put them on my Shiv (2013 bars) on the trainer yesterday -- they looked and felt fine. Can't say I noticed much of a difference from the originals, other than that these are new and the fabric covering isn't peeling away.
You can see the different layers of foam from the side (second photo). If the fabric covering starts to separate from these, I'll note the hours & mileage, then may try a bit of fray check along the edges.
They fit the pad holders well (third photo). Maybe there is a slight mismatch at the outer corners, but not enough that I would trim the pad or holder to correct. (Someone else on this thread had trouble with the fit, so maybe CeeGees corrected the cut since then?)
