I found someone who is selling a 2014 P5-Six Fork and Frame. Just the fork and frame. I'm curious to hear if it would be possible to fit a standard Hed aerobar to the bike, or if it only takes the P5 custom set up. I'm also curious about what type of brakes I'd have to use. Thoughts?
Re: P5-Six Fork and Frame with Standard Hed Aerobars [ttknight]
The P5 has a standard steer tube so you could mount any aero bars to it
Check out Caroline Steffen's setup (just fork, frame, standard stem... I think maybe -30 though... and a 3t cockpit I think).
I believe, but may be wrong, that while the steerer tube can accept a standard stem/bar combo, the brake fairing "beard" attached to the Aduro and the beard on Steffens bike was custom mounted.
Otherwise, source a P5-3 fork, sell the P5-6 fork, or swap, and run any bar you want.
Brake wise, any single post standard brake will work.
