Hi All. I have a 2015 Shiv with the specialized carbon aerobars. I replaced the stock side pull front brake with a TriRig Omega X front brake a while back. The cable routing on the bars is out the back near the stem, which left the cable flying out in the wind, which of course is unacceptable. The solution my LBS came up with is to zip tie the cable down to the bar, which works functionally, but the tension causes the front end to swing hard left whenever i pick up the bike, stopping only when it slams into the frame.
Anyone have a better way to run the cable? Thanks in advance
2016 Specialized Shiv Pro Race 1x
2015 Specialized Venge
