The brake is not fully releasing. This happens to me every once in a while and you just have to play with it until it fully releases. A few things I do when this happens:
- Unscrew the pivot bolts on the brake arm and clean them. I have seen these get bound up and not move freely.
- Clean the roller pins on the top of the brake arm where it contacts the wedge. Ensure the pins roll smoothly. Put some light lube on them (I have use old chain lube).
- Adjust the brake arm centering screws. Sometimes just adjusting them a bit frees things up and it will fully release. Don't ask me why on this.... sometimes it just works.
With the brake cover off, watch the brake as you engage it on and off. That will show you where it's getting hung up on.
blog
blog
