Hi Andy
if you're using the tilt cradle then the set screw does set the forward limit of adjustment. You can run the mono without the tilt cradle and get that little bit of extra forward adjustment if you only run a level extension but you may give up some stability that way (depending on how hard you pull on th e extensions while riding).
Carl Matson
Carl Matson
