Thanks for the additional info, Jorge. Every bit helps.
Couple of things...
As you noted, every washing or rain ride or sweaty trainer session will increase the risk of moisture getting in contact with things that rust. No bike is waterproof. Most people understand that powerwashing is bad news for forcing water into places it doesn't belong...but if you think about it, high pressure air can force that surface moisture past the seals too...and I'm not just talking about those exterior orange seals, but the seals on the bearings themselves. That's where I'm thinking your rust issues are the worst and why it keeps coming back. Regardless of how moisture got in there, if you've got rust started behind the bearing seals you can clean and regrease the exterior seals and surfaces all you want and the reaction keeps on going behind the seals.
None of that is to say there isn't a potential bearing or seal quality issue going on. Simply pointing out that, as you note, protecting that area is hard to begin with...and once compromised, there's not a lot you're going to be able to do about it short of replacement.
Sounds like you're doing most of the things which make sense as far as reducing risk. I'd just be careful with the compressed air around any bearings and/or bushings.
The Quality rep in my department says he's looking into it...that's all I know right now.
Carl Matson
Couple of things...
Carl Matson
