MAIN INDEX RULES & LEGEND LOG IN
Slowtwitch Forums: Triathlon Forum:
Official Speed Concept Owners Thread
First page Previous page 1 ... 171 172 173 174 175 ... 237 Next page Last page  View All
Carl
Apr 23, 12 6:05
Post #4301 of 5925 (24206 views)
Re: Official Speed Concept Owners Thread [GMAN19030] [In reply to] Quote | Reply
If you're partial to the PRS20 because it works well with your other bike(s) then you may have to make a custom pad to slip over the stock BB cradle to either protect your battery mount or your rear brake (after you take the rear brake cover off).
Otherwise, I have to say I'm partial to the extreme range clamp mounted in any of their regular stands.
Carl Matson
Trek Bicycles
Design Engineer - Speed
Carl
Apr 23, 12 6:13
Post #4302 of 5925 (24202 views)
Re: Official Speed Concept Owners Thread [simpy16] [In reply to] Quote | Reply
Thanks for the kind words. Now for the bad news...we don't offer touch-up vials for that color, and it's a custom formulation which doesn't have a Pantone equiv. In cases like this, we point you to your favorite hobby/model shop and their paint selection...almost always a Testors hue which is close enough. A bunch cheaper too.
Carl Matson
Trek Bicycles
joehysong
Apr 23, 12 6:17
Post #4303 of 5925 (24198 views)
Re: Official Speed Concept Owners Thread [Carl] [In reply to] Quote | Reply
Carl,
I am looking to Put a Disc on My Speed Concept 9.9 Do you have a recomendation? I know that only low profile tires will fit under the speed box. But what have you heard is working out there?
Thanks
GMAN19030
Apr 23, 12 6:25
Post #4304 of 5925 (24195 views)
Re: Official Speed Concept Owners Thread [joehysong] [In reply to] Quote | Reply
joehysong wrote:
Carl,
Thanks
I use the Hed Jet Disc C2 on my 9.9. Don't worry about the tire/speed box thing. That's a non-issue.
The only worries are adjusting the brakes to allow for wider rims and making sure the bulge of the disc doesn't hit the duotrap sensor.
(This post was edited by GMAN19030 on Apr 23, 12 6:26)
GMAN19030
Apr 23, 12 6:29
Post #4305 of 5925 (24192 views)
Thanks, Carl. No issues clamping the SC 9 frame to that?
Carl
Apr 23, 12 6:33
Post #4306 of 5925 (24189 views)
The only disk I've heard of having potential interference issues is the Lightweight. On the performance front, the KVF tube sections are quite a bit more robust than any of the full foils we've tested vs different disks...washing out the wheel choice sensitivities that some other brands may have.
Carl Matson
Trek Bicycles
Carl
Apr 23, 12 6:35
Post #4307 of 5925 (24185 views)
I clamp to the seatpost for most work...that's where the extended range design comes in very handy...wouldn't recommend clamping the frame.
Carl Matson
Trek Bicycles
TH3_FRB
Apr 23, 12 7:14
Post #4308 of 5925 (24169 views)
Isn't there a special clamp adapter specifically for the SC9 post?
Sisu Multisport & Endurance
Sisu Multisport & Endurance on Facebook
My blog - ON-ON (to Kona?)
Carl
Apr 23, 12 8:06
Post #4309 of 5925 (24140 views)
Re: Official Speed Concept Owners Thread [TH3_FRB] [In reply to] Quote | Reply
Yes, there is that too...he was looking to get a new stand anyway (as I read it) hence my recommendation. The SC post pads which fit in the 403494 post adapter are PN 416102.
Carl Matson
Trek Bicycles
wickert
Apr 23, 12 8:23
Post #4310 of 5925 (24135 views)
Re: Official Speed Concept Owners Thread [vikingmd] [In reply to] Quote | Reply
I'm trying to get my Rotor 3D in, and, very much like you said, the spindle is not long enough - in fact, I can measure the Q factor to be ~ 4mm wider than if I mount them outside the frame, which means clearly something is in the way. Should the bearings be pressed any further inside the frame or is there any other solution to this?
The easiest solution, to take it to my friendly dealer/mechanic, is unfortunately not available until the end of the week. I do have access to a rubber mallet though :)
Thanks in advance,
Ricardo Wickert | Team Radsport Pur - Germany | My sporadically updated blog: The Thin Grad Line | My team-issued TT bike: Trek Speed Concept 9
"What we think, or what we know, or what we believe is, in the end, of little consequence. The only consequence is what we do." (John Ruskin)
2013 Sponsors: Magnesium Pur | TrainX Training Systems | W3D Web Solutions | Trek Bikes via Bici-Sport Binder | Eat4Speed | Join them!
wickert
Apr 23, 12 8:32
Post #4311 of 5925 (24126 views)
Re: Pressing in BB's SC - Shimano [Carl] [In reply to] Quote | Reply
Hi Carl,
Carl wrote:
When fully seated the bearing faces will be parallel with and likely just "inboard" of being flush with the outer bore faces.
(besides the post above,) can you quantify this 'likely just "inboard" ' - are we talking 'barely perceptibly' or 1-2mm ? Should the distance between bearings, when measured outside to outside, not equal 90mm 'exactly' ?
I'm trying to figure whether I got something wrong with the crankset or with the bearings...
Thanks!
TH3_FRB
Apr 23, 12 8:36
Post #4312 of 5925 (24124 views)
Re: Official Speed Concept Owners Thread [wickert] [In reply to] Quote | Reply
If it is a 3d then you have a 30mm spindle and must be trying to use a pair of thin 4mm wide bearings on each side. I tried to make that work for a while but eventually accepted defeat short of modifying the frame.
wickert
Apr 23, 12 8:40
Post #4313 of 5925 (24123 views)
Nope, 3D has the regular 24mm spindle, while 3D+ is the one with the 30mm spindle. I have the stock Enduro bearings from Trek, no modification done there :)
Carl
Apr 23, 12 8:49
Post #4314 of 5925 (24116 views)
Re: Pressing in BB's SC - Shimano [wickert] [In reply to] Quote | Reply
Barely perceptibly to maybe 1mm. Think I remember some conversations about the Rotor spindles being a bit of a tight fit on the bearings, too...ah yes, right here.
Carl Matson
Trek Bicycles
wickert
Apr 23, 12 8:53
Post #4315 of 5925 (24112 views)
Great, thanks for the tip. I'll grab some sandpaper on the way back home and give it a try. Cheers!
vikingmd
Apr 23, 12 9:09
Post #4316 of 5925 (24100 views)
I didn't have problems fitting the spindle through the bearings but the length was barely long enough for the non-drive side crank arm to fit with the rubber bearing covers and the metal washers. I eventually just removed the rubber bearing covers.
TH3_FRB
Apr 23, 12 9:26
Post #4317 of 5925 (24091 views)
My bad - was thinking 3D was the bigger spindle for some reason. I didn't have any issues with my Rotor cranks fitting. The tolerance going through the bearings is extremely tight to the point that it needs to be perfectly aligned to slide through otherwise you'll swear the spiondle is a hair too big. As for total width, I think I measured mine at ~91mm with bearings pressed in.
TH3_FRB
Apr 23, 12 9:59
Post #4318 of 5925 (24068 views)
Re: Official Speed Concept Owners Thread [In reply to] Quote | Reply
Thanks to a rainy Sunday I got to spend some time in the garage tinkering. On my previous bike I had a standard alu bottle cage between the aerobars with zip-ties. It works well and was very simple and inexpensive. I set it up the same on my SC but got to thinking about a cleaner alternative that would also allow me to move my Garmin 500 up by my hands instead of way back on the stem cap where it's difficult to see. I'm running the 100/10 stem that has a completely flat cap. This might also work on the 50/10 assuming it is long enough to fit the mounting holes for a cage. The parts are simple and aside from the cage this is dirt cheap. It pained me to drop $30 on a waterbottle cage but the white carbon cage looks the part better on the SC so I made the investment.
Here are the supplies and prep. I used a pair of t-nuts (without prongs), 10-24 allen head screws, and some nylon spacers. First figure out where on the cap you want the cage to be, then mark and drill a set of holes just big enough for the t-nuts to fit through. I wanted my cage as far forward as possible so I trimmed the flange on the front t-nut to go around the stem cap screw hole. Then take your adhesive and glue the t-nuts in place. Once the adhesive sets up you can use the nylon spacers to mount the cage and you're done. Because of the tilt in my aerobars I needed the front of the cage to sit a little higher so I beveled the top surface of both spacers for the angle that the cage would sit at.
And here is the finished product. Stem cap goes on/off just as before.
(This post was edited by TH3_FRB on Apr 11, 13 9:13)
TH3_FRB
Apr 23, 12 10:05
Post #4319 of 5925 (24064 views)
Now on to the Garmin 500. I picked up a 2ft section of 1" pvc pipe from HD for $3. Add a couple zip ties and some Dremel time and you get this. It's probably temporary until the next rainy day - I want to mount to sit a bit lower between the bars and I have an idea for making it a bit cleaner.
And everything together. The angle makes it look like there is more space between the bottle and Garmin than there really is. Right now the bottle barely gets into the cage past the Garmin. Getting the Garmin mount lower between the bars will help tighten it up more. Even as it is I don't have any issues with my hand placement - I hold out at the very ends of the aerobars with my thumb and index finger on the shifters.
(This post was edited by TH3_FRB on Apr 23, 12 10:21)
csukitay
Apr 23, 12 12:37
Post #4320 of 5925 (24022 views)
Carl,
I tried ordering the following parts from my LBS in Feb, but they have yet to get them in. Do you have any insight into stock levels? SC RXL P-clamp (420492) and padhardware (420487 pads & 420488 pad holders)
Thanks!
Adam
Carl
Apr 23, 12 12:48
Post #4321 of 5925 (24025 views)
Re: Official Speed Concept Owners Thread [csukitay] [In reply to] Quote | Reply
Keeping in mind I can only "see" domestic stocks...and even then I don't have realtime capability (to my knowledge)...all three PNs appear to be available. Your dealer's rep probably has better info.
Carl Matson
Trek Bicycles
KurtJ
Apr 23, 12 18:09
Post #4322 of 5925 (23975 views)
I am new to triathlons, but not riding or running. That being said I am looking at buying a Speed Concept 7.5. I was fit by my local bike shop and they said I was a S or a M in Trek. I test rode a M (on sale) and it seemed pretty comfortable. They didn't have a S available. The question is: should I go ahead and buy the M or wait until I ride a S? I am 5'8. My previous road bike was a fuji M (50 cm).
Carl
Apr 23, 12 18:42
Post #4323 of 5925 (23963 views)
Re: Official Speed Concept Owners Thread [KurtJ] [In reply to] Quote | Reply
The most important thing you can get out of a fit session is where your armpads are, vertically and horizontally from the BB. The rest of the bike depends on those coordinates. Whether your shop ended the fit session by giving you those numbers, or by handing you a sheet with a bunch of other numbers let's see what you've got and see what they're trying to tell us. I can make a guess from your height and your road bike fit, but it would have no better than a 50-50 chance of ending up in a happy place...IOW, exactly the situation you're in right now.
Carl Matson
Trek Bicycles
timboricki
Apr 23, 12 18:55
Post #4324 of 5925 (23955 views)
GMAN19030 wrote:
joehysong wrote:
Carl,
Thanks
On the DuoTrap note - I ride with a garmin and really only use the DuoTrap for cadence (since the Garmin measures speed/distance/etc). If I take the DuoTrap sensor out for racing (when I use a disc or wheel cover) are there any anticipated disc/cover issues? Or is it only the DuoTrap sensor arm that is an issue.
I suppose, that I could put back on the Garmin cadence sensor in this case.
lmbasell
Apr 24, 12 5:36
Post #4325 of 5925 (23886 views)
Carl - are there any issues with running the Zipp 808 Clinchers on a SC9.9? I know they are quite wide and just want to make sure they are ok before purchasing.
Market Influence
What influences your swim/bike/run product buying decisions most? The use of products by, or comments made by or in:
Pro cyclists?
Pro triathletes?
My non-Slowtwitcher friends?
Forum members and other Slowtwitchers?
Slowtwitch tech articles and forum moderators?
Other magazines?
Manufacturers?
My LBS?
Ratings/comments on other websites?
Other
