MAIN INDEX RULES & LEGEND LOG IN
Slowtwitch Forums: Triathlon Forum:
Official Speed Concept Owners Thread
First page Previous page 1 ... 170 171 172 173 174 ... 237 Next page Last page  View All
Carl
Apr 14, 12 10:20
Post #4276 of 5921 (24965 views)
Re: Official Speed Concept Owners Thread [kimaswan] [In reply to] Quote | Reply
As runless noticed, they are in fact long brake nuts. Any shop should have some. Just make sure it's the same length as the original.
Carl Matson
Trek Bicycles
Design Engineer - Speed
Turbeau
Apr 15, 12 18:50
Post #4277 of 5921 (24827 views)
Re: Official Speed Concept Owners Thread [lmbasell] [In reply to] Quote | Reply
yes it will fit it perfect, the brake width just has to be adjusted slightly as with any wider rim. I rode this wheel on my SC last month with absolutely no issues.
http://www.turbeaucurbeau.wordpress.com
turbeaucurbeau@gmail.com
QT2 Systems - Athletes Lounge - Towpath Bike
stevej
Apr 16, 12 11:11
Post #4278 of 5921 (24717 views)
Re: Official Speed Concept Owners Thread [Turbeau] [In reply to] Quote | Reply
Looking into getting a Quarq S975 GXP power meter to replace my ultegra crank on my SC 9.5. I realize I need to change the bb bearing's from shimano to SRAM/GXP. Is it worth it to get ceramic or stick with steel? I'm not even sure what is on my bike currently. Can someone help me out. BB and all the compatibility is really confusing me.
Carl
Apr 16, 12 11:23
Post #4279 of 5921 (24703 views)
Re: Official Speed Concept Owners Thread [stevej] [In reply to] Quote | Reply
if it was a stock 9.5 you're on steel bearings. I believe only the 9.9 ever came stock with ceramics.
GXP bearing kits for BB90 use exactly the same bearings as regular GXP BB kits...only they're "loose" instead of being prepackaged in cartridge-ish carriers. Slowman's primer is a good one.
I've got no strong feelings on the steel vs ceramic proposition, so I'll leave that alone. The PNs your Trek dealer will be looking for depending on which way you decide to go are:
for SRAM/GXP:
411814 for ceramics
404700 for steel
Carl Matson
Trek Bicycles
hzoota
Apr 17, 12 9:38
Post #4280 of 5921 (24539 views)
Re: Official Speed Concept Owners Thread [Carl] [In reply to] Quote | Reply
I am in the process of purchasing a 2011 Trek Speed Concept 7.0 on closeout and have read that the original seat post or binding on this bike tended to slip and Trek supplied a new or different seat binding that resolved this issue. I have looked around the Trek website but do not see recalls or notices about this issue. Does anyone know how can I tell if the seat binding has been updated on this bike or if it is the original one that may need to be changed.
Thanks,
Herb
Carl
Apr 17, 12 9:54
Post #4281 of 5921 (24535 views)
Re: Official Speed Concept Owners Thread [hzoota] [In reply to] Quote | Reply
Easy: the new wedge has a 7.2Nm max torque recommendation printed on it...the old one had 11Nm. It was included in a dealer service bulletin.
Whether it comes with the new one or you get a replacement for the old, 7.2 is a max...not a minimum...not a starting point...it's there IF you need it. Best practice for max torques is to sneak up on them. Start with 4Nm and see if you slip. Then 5Nm, etc.
Carl Matson
Trek Bicycles
MccrystalB
Apr 17, 12 12:36
Post #4282 of 5921 (24475 views)
hi carl or anyone!!
I got SC 9.9 frame and my LBS was building it with di2. They ran into difficulty with the inner cabling that connects to the battery, front and rear mech. (The bars were ok)
Has anyone had this problem and it seems that di is like hens teeth!!
help.. ive a race in a few weeks and id like to be on my new ride!
thanks.
BMC
Carl
Apr 17, 12 12:39
Post #4283 of 5921 (24472 views)
Re: Official Speed Concept Owners Thread [MccrystalB] [In reply to] Quote | Reply
Need more details... What was the difficulty, are they trying to install the external wiring harness instead of the internal, etc?
Carl Matson
Trek Bicycles
MccrystalB
Apr 17, 12 13:10
Post #4284 of 5921 (24446 views)
hmm.. let me find out for sure. check back tomorrow(irish time here)
thanks carl
BMC
paxfobiscum
Apr 17, 12 13:25
Post #4285 of 5921 (24430 views)
That should be pretty straightforward. I did my own Di2 wiring and I am not even a bike mechanic. The wires are all long enough to have sufficient slack to connect all of them first before pushing them back into the bottom bracket and covering up with the plastic cover.
.........................__0.............0
...................._.-\ <,_.........</\_
.....~_.o^,....(...)./.(...)......._/\...
MccrystalB
Apr 17, 12 13:36
Post #4286 of 5921 (24421 views)
Re: Official Speed Concept Owners Thread [paxfobiscum] [In reply to] Quote | Reply
I agree.. i havent seen the bike or the job as i was away but from the call he says that the cable is too big to push through!. i will find out more. I thought it would be stright forward myself
thanks
BMC
Carl
Apr 17, 12 13:40
Post #4287 of 5921 (24417 views)
might have been trying to send the wrong end through ... Skinny ends of the connections enter frame from the outermost points and meet at the BB. Anti-rattle zipties can make the entry at the rd exit a bit tight, but they will fit through.
ETA: fixed smartphone typos
Carl Matson
Trek Bicycles
(This post was edited by Carl on Apr 17, 12 13:59)
MccrystalB
Apr 18, 12 5:28
Post #4288 of 5921 (24313 views)
Hi Guys, LBS has given me a link for what i need. He must be using a different cable system and it isnt compatible!
http://bit.ly/IlqaUl
BMC
BMC
Carl
Apr 18, 12 5:36
Post #4289 of 5921 (24307 views)
that's the internal wiring harness...bet he was trying to run the external?
if he doesn't already have it he'll also need the SC Di2 conversion kit PN 422802 which includes, in addition to the Di2-specific rear brake cover, our own short battery rail. the spacing on Shimano's short rail isn't quite right for the mounts on that brake cover. 1.5mm hex is all you need to remove the stock rail bolts and make the switch.
Carl Matson
Trek Bicycles
MccrystalB
Apr 19, 12 3:13
Post #4290 of 5921 (24185 views)
HI Carl. thanks for that, It looks like it is very hard to get that.
How long does the cable have to be??
ps. if anyone here has access or know anywhere this part could be instock please pm me. It seems shimano are out of stock and giving june delivery. I need someone that has it in stock now.
i have IM lanzarote coming up and would love to be ready to roll for it!!
thanks
BMC
Carl
Apr 19, 12 4:59
Post #4291 of 5921 (24167 views)
one length to the internal harness and it covers all five sizes of SC. if you can find one, you're good to go. I'd love to help with availability, but I can't see into our non-domestic warehouses.
Carl Matson
Trek Bicycles
MccrystalB
Apr 19, 12 11:29
Post #4292 of 5921 (24094 views)
carl would it be a daft idea to set it up externally until the interal cable arived???
BMC
Carl
Apr 19, 12 12:00
Post #4293 of 5921 (24080 views)
I don't know if I'd call it daft, but certainly more difficult...cable length now does come into play as there are several options for various frame sizes. Also need to figure out how & where to attach the main junction at the BB.
Carl Matson
Trek Bicycles
diarmuidhere
Apr 19, 12 14:14
Post #4294 of 5921 (24048 views)
Re: Official Speed Concept Owners Thread [SpeedRacer1] [In reply to] Quote | Reply
Hey man, dont mind the haters.
I think thats one good lookin bike. I have the same bike and im just wondering what make/model is the rear mounted bottle holder? And if you know anywhere in Ireland I can buy or order online?
MccrystalB
Apr 20, 12 23:11
Post #4295 of 5921 (23909 views)
hi carl, i think i got the last cable in the world!! met a guy iin belgium at tristar mallorca http://www.deeweebikes.be/ I sent him a mail on the off chance and he located one in the US. http://www.velomine.com/
cant thank them enough.
cheers
BMC
GMAN19030
Apr 22, 12 10:26
Post #4296 of 5921 (23718 views)
I'm looking to finally buy a repair stand. I'd like to go with a no clamp version like the Park PRS-20.
http://www.parktool.com/...am-race-stand-prs-20
My SC is equipped with Di2 and it doesn't look like it will work well with that stand since the Di2 battery will be in the way in regard to where the BB is supposed to sit on the stand.
Anyone have any recommendations?
cyclingdoc
Apr 22, 12 14:07
Post #4297 of 5921 (23667 views)
I'm having trouble interpreting the fit chart, and was looking for some help.
I think I need a large frame, but I'm not sure on the proper stem size.
Current measurements:
Arm pad stack - 67cm (maybe move to 68cm)
Arm pad reach - 46cm
Saddle height - 77.5cm
I am 6'1" tall (not that it matters)
Thanks you,
Jack
Runless
Apr 22, 12 14:12
Post #4298 of 5921 (23658 views)
Re: Official Speed Concept Owners Thread [cyclingdoc] [In reply to] Quote | Reply
Looks to me like 60/45 with a couple cm of spacers.
Honestly, you're fairly tall/short for a SC but it's not a terrible fit.
simpy16
Apr 22, 12 17:36
Post #4299 of 5921 (23591 views)
Carl,
I need your help with a problem I am having with my SC0. The paint is starting to flake off the bottom of my fork near the dropout.
What can I do to stop that? Also where can I get some touch up paint that matches the color of the red used on the bike last year?
Thank you again for all you do for us owners or prospective owners!
Love, love, love the bike....now trying to find the right saddle is a different story. When Lance is done with is saddle can you have him ship it to me to try?
Carl
Apr 23, 12 5:58
Post #4300 of 5921 (23516 views)
Runless nailed it. Large with 60/45, one notch forward of nominal on the pads.
Carl Matson
Trek Bicycles
Market Influence
What influences your swim/bike/run product buying decisions most? The use of products by, or comments made by or in:
Pro cyclists?
Pro triathletes?
My non-Slowtwitcher friends?
Forum members and other Slowtwitchers?
Slowtwitch tech articles and forum moderators?
Other magazines?
Manufacturers?
My LBS?
Ratings/comments on other websites?
Other
