Bike Shops
Coaches
Fitters
Race Calendar
Running Stores
Store
Stack & Reach
Training Log
Triathlon Clubs
We Noticed
MAIN INDEX
RULES & LEGEND
LOG IN
Slowtwitch Forums
Official Speed Concept Owners Thread
1
167
168
169
170
171
238
View All
Tri
Classifieds
Lavender
Jobs
Womens
Notices
Print Thread
StoneRoses
Mar 30, 12 5:23
Post #4201 of 5928
(25340 views)
Re: Official Speed Concept Owners Thread [Carl]
In reply to
Quote
Reply
Carl,
Thanks for your PM.
Unfortunately, I can't reply your PM since I'm not allow to send PM. (New user restriction?)
Could you please PM me your email address?
elf6c
Mar 30, 12 12:12
Post #4202 of 5928
(25263 views)
Re: Official Speed Concept Owners Thread [SC_NICK]
In reply to
Quote
Reply
I think my favorite thing about my 9.9 is how adjustable the front end is. Very happy with the ability to adjust to my preferred 40k TT position without heroics. That has not been the case with a few other front ends I rose in the past.
Although a high quality torque wrench is obviously mandatory even all the random, but very specific torque settings.
berndl
Apr 1, 12 15:02
Post #4203 of 5928
(25110 views)
In reply to
Quote
Reply
Hi Carl
My derailleur settings were being an issue and I managed to figure that the bb cable guide was the culprit. Trying to loosen the fastener that holds the bbcg I noticed that the entire fastening assembly rotated. The clinching bolt in the frame was loose hence the loose bbcg. I have managed to drill out the fastener and remove the entire clinching bolt. It seems though that the aperture in the frame has enlarged somewhat. Is the clinching bolt installed prior to moulding of the bb section or done post production. ie will I be able to re-install a slightly larger clinching bolt and properly this time re-attach the bbcg?
thanks
bernd
Btmagician13
Apr 1, 12 19:33
Post #4204 of 5928
(25042 views)
Re: Official Speed Concept Owners Thread [berndl]
In reply to
Quote
Reply
Carl,
I once ran across something on here from someone saying that the first generation draft boxes were not fitted to the frame properly.
Well, Saturday I was going about 24 mph on a flat and all of a sudden my rear wheel completely locked up. I am amazed that I did not go down although I went completely sideways and I am also fortunate my wife was far enough behind me not to hit me. Well, the draft pack top portion came off and the bottom bracket jammed into my tire. The road burned straight through my tire and almost ruined my wheel.
Question here is this, is there a recall on the draft box that I do not know about? I feel like at the very least I should get a replacement draft box. It would be nice if they would give me another tube and tire.
Any thoughts?
"Tri Harder"
Beach 2 Battleship 2010 - 12:37:00
IM Florida 2012 - 11:29:50
cycleguy0623
Apr 1, 12 19:50
Post #4205 of 5928
(25029 views)
Re: Official Speed Concept Owners Thread [Btmagician13]
In reply to
Quote
Reply
I had a similar incident with my draftbox a few weeks ago. My lbs here in Dayton was able to get the speed box replaced for me under warranty. I didn't burn through my tire thank god so I cant answer that part of your question. I have about 200 miles on the new draft box and it works great.
berndl
Apr 2, 12 0:45
Post #4206 of 5928
(24992 views)
Re: Official Speed Concept Owners Thread [cycleguy0623]
In reply to
Quote
Reply
wew all these issues!!!!!! draft boxes falling down, squeaky headsets, b b cable guides coming loose, coroding bolts and fasteners, no replacement parts available etc etc, hmm I have never had these issues with my 13 other italian bikes over a period of 25 years.
I think I will turn my speed concept or 'squeak concept' into a single speed fixie or use it as a stand outside the front door of my bussiness to hold up my advertising board maybe with a wicker basket attached to the handlebar with flowers in it.
arilehtio
Apr 2, 12 1:20
Post #4207 of 5928
(24975 views)
In reply to
Quote
Reply
Yep. I agree!
I had also problems with speedBox attachment and two build quality issues with SC frame in half year (one cracked frame and one frame mold failure). Great riding feel and looks great but quality.... Carls team should do something for build quality processes in factory's, I think...
BS
Ari
StoneRoses
Apr 2, 12 1:55
Post #4208 of 5928
(24957 views)
In reply to
Quote
Reply
First of all, I would like to thanks Carl for his support in my case.
I have SC9.9 with all of those flaws mention here (except the seat post slipping problem).
Squeaking problem is the one that I think Trek should consider a recall since the root cause of this problem might compromise the headset integrity and in my case, a serious safety issue.
If you have preload nut in natural aluminum color, you should consider replace with the new black preload nut or adding shim around it.
Carl
Apr 2, 12 6:32
Post #4209 of 5928
(24892 views)
In reply to
Quote
Reply
it's a post-production piece called a riv-nut or nut-sert. some shops have a repair capability which allows them to remove the original and replace with the same part. in your case, now that the original hole has been enlarged, you will have to try and find an M5 riv-nut with a larger flange or pull the cranks and BB and use a standard hex nut on the backside. it's possible a bike shop would have a larger flange nutsert and installation tool. recommend adding epoxy to the former (only to the exterior - keep it out of the threads!) and blue locktite for the latter.
Carl Matson
Trek Bicycles
Design Engineer - Speed
Carl
Apr 2, 12 6:50
Post #4210 of 5928
(24883 views)
In reply to
Quote
Reply
more accurately, the original draft boxes did not clamp up to the frame as well as intended (they fit fine, but could slip down and reduce tire clearance...sometimes rubbing tires), hence the redesign.
the 2nd generation draft box has been available to all original owners of the 1st box as a no cost warranty item since about this time last year. your Trek dealer should have no problem obtaining one: PN420505 and in stock in all domestic warehouses.
Carl Matson
Trek Bicycles
Carl
Apr 2, 12 7:04
Post #4211 of 5928
(24870 views)
In reply to
Quote
Reply
I don't know how long you've had you Speed Concept, but all the items you mention have been addressed...most of them for about a year now. If the assembly date of your bike predates those fixes there are a number of no-cost replacements (labor not included) available to you,
many of which are listed here
. If you have other specific concerns let me know and I'll do my best to point you or your Trek dealer to the right part numbers or processes to remedy the issue.
Carl Matson
Trek Bicycles
Carl
Apr 2, 12 7:07
Post #4212 of 5928
(24867 views)
Re: Official Speed Concept Owners Thread [StoneRoses]
In reply to
Quote
Reply
see post 4211 below regarding warranty replacements for the most common 1st-generation Speed Concept parts concerns. or just click
here
Carl Matson
Trek Bicycles
arilehtio
Apr 2, 12 8:07
Post #4213 of 5928
(24837 views)
In reply to
Quote
Reply
This is interesting! When I saw fracture of my original frame, seat post clamp was 7.2 Nm version, now my Trek warranty replacement frame (wich is also going to warranty...) has 11 Nm version? So my conclusion is that Trek replaces my original newer frame to older version of 7.5 model with all those replacement programs?
- Ari
Carl
Apr 2, 12 8:38
Post #4214 of 5928
(24819 views)
Re: Official Speed Concept Owners Thread [arilehtio]
In reply to
Quote
Reply
Only if the warranty replacement was new old stock. Not sure how that would happen, but it may explain what you're seeing. Still, even in that case all the 1st generation replacement parts would apply as needed.
Carl Matson
Trek Bicycles
arilehtio
Apr 2, 12 9:06
Post #4215 of 5928
(24808 views)
In reply to
Quote
Reply
Thanks Carl for information.
LBS said that the replacement came straight from the TREK U.S.A.That's why I had to wait it like month in last summer.... So it can't be "new old stock"?
- Ari
Carl
Apr 2, 12 9:34
Post #4216 of 5928
(24788 views)
In reply to
Quote
Reply
Depends on what is in the warranty warehouse. Their inventory turnover isn't the same as regular distribution (happily...except perhaps when it causes something like this). Still, we're always looking to improve our processes and can't act on what we don't know is happening, so I'll send a note to our warranty department as a heads-up with your experience as an example. Thanks for bringing it up.
Carl Matson
Trek Bicycles
berndl
Apr 2, 12 13:56
Post #4217 of 5928
(24742 views)
In reply to
Quote
Reply
Thank you Carl. I took the removed nut to a specialised fastener consultant. He noted before, I explained to him where the item came from and its function, that it had been installed improperly (scew) The bracket into which the riv-nut is inserted is too thin to accomodate a larger M5 nut. The consultant indicated it might crack the bracket due to the now possible greater force required to compress an M5 riv-nut. In my opinion it renders the frame useless. Also if it has been installed incorrectly at the factory then this is now a warranty issue. perhaps a frame replacement.
and
again thanks for you kind personal input and assistance I appreciate it
I bought my 9.5 from Cycle Werks in Los Angeles in october 2010 and my wife bought hers from Cycle Lab in South Africa in february 2011. The bottom bracket cable guide issue is related to my wife's bike. mine just sqeaks. Do I request the replacement parts from my local Trek dealer here in the UK where I live or do I request sets from each dealer in two different countries? Or directly from you?
Thanks
Bernd
Carl
Apr 2, 12 14:12
Post #4218 of 5928
(24728 views)
In reply to
Quote
Reply
Ideally the requests go through the shops where the bikes were purchased, but in your case this isn't really efficient. You should be able to work through your nearest Trek dealer. Having some sort of proof of original ownership to show them wouldn't be a bad idea.
Whether the rivnut was installed improperly to begin with or not, your dealer might've been able to remove and repair it without enlarging the hole as you did. Our factory repair center definitely could've. I don't know what effect this may have on your warranty standing. You could check with our customer service personnel via
this link
, or just explain to the Trek dealer when they file the claim.
Carl Matson
Trek Bicycles
TH3_FRB
Apr 3, 12 18:47
Post #4219 of 5928
(24601 views)
In reply to
Quote
Reply
What is everyone using for mounting their computers? I have a Garmin Edge 500 that I previously had on the stem of my last bike. I stuck it on one of the aero bars this past weekend for a duathlon but it won't be able to stay there - hits my arm plus I'm putting a water bottle between the bars. It would fit between the pads but has to twist to lock into the mount and that isn't happening between the pads.
Sisu Multisport & Endurance
Sisu Multisport & Endurance on Facebook
My blog -
ON-ON (to Kona?)
ojorgenson
Apr 3, 12 20:54
Post #4220 of 5928
(24564 views)
In reply to
Quote
Reply
Carl, how do I know if I have a first generation draft box that needs to be replaced? No apparent slippage yet, but I don't want a disaster like the ones described! Bought my SC 9.5 in August '11. Thank you!
Carl
Apr 3, 12 21:14
Post #4221 of 5928
(24557 views)
Re: Official Speed Concept Owners Thread [ojorgenson]
In reply to
Quote
Reply
pix
here
. basically, you're looking for "wings" on the upper section similar to those on the bottom.
Carl Matson
Trek Bicycles
berndl
Apr 3, 12 23:55
Post #4222 of 5928
(24520 views)
In reply to
Quote
Reply
Hi Carl
I registered the bikes on TREK's website so it shouldn't be an issue for you to establish my proof of ownership.
regarding your possible allusion that I possibly wantonly hacked away at the rivnut fastener and that I am incabable of delicate work is premature. I am a cabinet maker by trade and delicate craftmanship is my forte.
As a matter of fact the nearest trek dealer that I went to to have the bb bearings pulled approached the frame with a big hammer and blunt pin to 'drift' the bearings out. Using that approach I seriously doubt that the carbon bracket mounting for the bb cable guide would have survived your appointed dealer's approach . They also could not diagnose the initial issue of the bb cable guide being loose and hence affecting the shifting. They as a matter of fact threw their hands up in the air and said that have no idea.
Why doesn't TREK do a recall on all Speed Concepts and address all these issues. We owners have registered our bikes as said on your site, thus you have our details. You produce high end (price wise) products maybe you should adopt the approach of the motor industry in instances like this. I am now expected to invest a lot of time and effort and as a consequence money to run around fixing a myriad of issues that I have not caused or am responsible for. Hell if my Porsche had an issue the dealer would knock at my door and collect the car and within a short while I will be informed that the problem is addressed and resolved with minimal impact to my time and life.
At the end of the day we are not talking about a kettle or a toaster, a bicycle is a mode of transport and I have my body on it. If anything fails it could potentially be fatal. After all this I per chance don't know now if a TREK, or to be fair a Speed Concept, product is safe to ride on anymore.
I KINDLY REQUEST THAT THE CEO OF TREK EMAIL ME AND RESOLVES THIS ISSUE get the chief to roll up his/her sleeves on this one.
Carl I thank you for your effort , courtesy and concerns but a forum is not the most savoury platform to find a resolution to this agenda.
Bernd
Livetotri
Apr 4, 12 6:37
Post #4223 of 5928
(24459 views)
In reply to
Quote
Reply
Anybody have any suggestions for an aerodynamically efficient way to secure my Hutchinson Fast'Air?
Various junk for sale
Eli Curt Fuld
keithisme
Apr 4, 12 6:44
Post #4224 of 5928
(24453 views)
Re: Official Speed Concept Owners Thread [TH3_FRB]
In reply to
Quote
Reply
Joel, I also had this concern. I bought a piece of carbon tubing from Vision that runs between the aerobars. Computer mount from Vision. It doesn't fit perfectly on my 7.8 SC, but it's close enough, and looks great.
Panabax
Apr 4, 12 6:56
Post #4225 of 5928
(24442 views)
Re: Official Speed Concept Owners Thread [Livetotri]
In reply to
Quote
Reply
I use the Dark Speed Works bento box designed for the SC. It is much more useful than the Trek bento and it will easily hold the Hutchinson Fast Air and more.
Panabax
We’ve heard that a million monkeys at a million keyboards could produce the complete works of Shakespeare; now, thanks to the Internet, we know that is not true.—Robert Wilensky
1
167
168
169
170
171
238
View All
Print Thread
this forum
this category
all forums
All words
Any words
Whole Phrase
The New Specialized Wind Tunnel
Will this be a game changer for Specialized, in both sales and product design, or will it not move the sales and design needle versus those in Specialized's competitive set?
Yes, Game Changer
Minor move forward
Won't budge the needle
