Burnt Toast,
The electronics cap is relatively sealed to the outside environment but if water is introduced to the battery terminal or connection between the cap and hub giving it some time to dry is a good idea. There is a thin red ring seal that fits around the PowerCap and does a really good job of keeping out water. The ring comes coated with a light grease that serves to further improve the sealing ability. If your ring seal is dry reapply some grease after letting the hub dry a little and you should be good to go.
Power on!
PowerTap Product Manager
Power on!
