Couple things-
The issue you're describing is actually due to the type of display being used in the Joule GPS vs. the LYC or Joule. The Joule GPS uses a full-dot matrix while the Joule and LYC use what's commonly referred to as a segmented display. Manufacturers like us like full dot matirx displays because we can program just about anything and display it, this makes adding features (like your request for the clock on the dashboard) possible. However, that flexibility typically comes at the expense of some readability. Segmented displays are easier to see, especially in direct sunlight or when the sun is low but the display is literally burned into the glass so we're limited in what we can display where on the glass and once we've locked it in that's it. This is why so many things on the LYC are kind of cryptic- we wanted to offer a feature and made a way to show it on the screen with the characters we had.
Before giving up, try playing around with different numbers of metrics on the dashboard, 4 seems to work well for readability but 3 might be better. Adjusting the contrast to something darker will typically be better for the conditions you're describing and also play around with the angle of the computer itself. We've designed the display to actually be easier to read if the computer is slightly more level. Hope that helps.
mcycle wrote:
Jesse-
I recently purchased the Joule GPS after being a long time LYC computer. The LYC had to go as I purchased a G3 wheel. Maybe I'm a simple person, but the resolution on the LYC is better than the Joule GPS in bright morning/evening time periods and if you can't see what you need to see, all the fancy bells and whistles don't mean as much.
Questions- I've read the manual and think I am fairly comfortable with many of the basic settings/setup.
1) That being said, on my very first morning sunny ride today with the computer- the glare on the computer in the earlier AM hours- 8-10AM- was difficult to see the screen. I've never had this issue with the LYC or prior cateye type computers. I also have the contrast on a lower setting, as high contrast seems to make it harder to see. Any suggestions?
2) The clock is really, tiny. I want to have it as one of my options on my dashboard- so I can actually see it. Can I do this- if not, you really should allow this as an option in a firmware upgrade. As- the question above with the screen hard to see at different times- makes seeing the tiny font all but impossible, especially in motion. Plus, it's so tiny that I would have to be stopped at a red light and put my nose close to the screen to actually read the time, during certain times of day. The LYC never an issue as you could just swap ride time to time of day and the font size was easy to see. I have perfect 20/20 vision....
3) I'm thinking about getting the Joule computer if the resolution is better than the Joule GPS. Is it more comparable to the LYC resolution? Is the Joule resolution better/worse/same as compared to Joule GPS?
Thanks-
Mark
P.S. G3 hub is very nice- stiffer wheel and bearings seem nicer.
Jesse Bartholomew
