I got a new tri bike last week and I had a Quarq w/ Rotor aero chainring installed, mostly because this is a purportedly aero combination with the closed spider. I have been using PowerTap P1 pedals for the last ~1.5yrs, and before that always used PowerTap wheels w/ a brief foray into an SRM for a year. Anyhow, I noticed in my first couple trainer rides that harder efforts appeared to produce a significantly higher than normal power reading on the Quarq, then I did a long ride last Thursday where my average power for almost 6hrs was only ~15W shy of my best 1hr power for the year. So today I built an interval workout in Garmin Connect, downloaded it to a 735XT and a Garmin Edge 510, connected the 510 to the Quarq and the 735XT to my PowerTap Pedals, synchronized the start of the workout, and set off to see what happened. Here goes:
5min warmup: 84W Quarq, 80W P1 (P1/735XT seemed to take a bit before it read anything other than zero, so wasn't too worried about this).
2min interval: 177W Quarq, 176W P1 (dang, maybe I did get a ton faster!)
3min recovery: 109W Quarq, 107W P1
2min interval: 205W Quarq, 198W P1 (3.5% difference, could be worse)
3min recovery: 98W Quarq, 90W P1 (yikes, that's ugly)
2min interval: 234W Quarq, 222W P1 (5.4% difference, no longer acceptable!)
3min recovery: 84W Quarq, 75W P1 (more than 10%!)
2min interval: 260W Quarq, 244W P1 (6.5% difference, keeps getting worse!)
3min recovery: 114W Quarq, 102W P1 (still more than 10%!)
2min interval: 277W Quarq, 261W P1 (6.1% difference)
After this I decided to hop off the bike and recalibrate each power meter. The Quarq didn't change much, remained in the 280s, the PowerTap went from 10->5. I suspect that isn't a huge change, but don't really know. Recalibrating on the 735xt required stopping the interval session, so I was no longer synced up. I did manage to do one more synced interval up a hill after the recalibration which resulted in 271W for the Quarq vs 259W for the P1 (4.6% difference).
I'm just curious if anyone has any ideas on something I should do to try and sync them more closely? Or at least get the percentage difference to be more consistent? Also wondering if there are opinions on which is more accurate? My bias is that the PowerTap is likely more accurate. I'm disappointed to have this trouble, I had read a fair bit of DC Rainmaker's reviews on power meters and it seemed most power meters are reading within 2-3% of each other across brands in his experience. I want to be able to move back and fourth between bikes seamlessly, so leaving the issue as-is probably doesn't work for me.
Dimond Bikes Superfan
