http://exploro.3tcycling.com/
THAT'S RIGHT our Sqaero shapes are designed to be as fast dirty as they are clean. The Exploro uses Sqaero 50/25, with a 50mm wide downtube perfect to pick up the airflow coming off a wider cross or mtb front tire and lead it on to the water bottles. The seattube is 25mm wide to make it aerodynamically disappear in-between the bottles and the rear tire. The headtube, seatstays and custom seatpost also use Sqaero shapes.
Quote:
GO SLOW FASTER:the best gravel rides are long and grueling, so saving a few Watts is very welcome. Enter our Sqaero shapes, squared-off aero shapes that are structurally efficient and fast. Sqaero shapes offer RealFast™ aerodynamics; they are faster not only under perfect conditions but also in the real world. Even when co vered by mud and muck. THAT'S RIGHT our Sqaero shapes are designed to be as fast dirty as they are clean. The Exploro uses Sqaero 50/25, with a 50mm wide downtube perfect to pick up the airflow coming off a wider cross or mtb front tire and lead it on to the water bottles. The seattube is 25mm wide to make it aerodynamically disappear in-between the bottles and the rear tire. The headtube, seatstays and custom seatpost also use Sqaero shapes.
