New 11sp on 10sp Wheel Option
I was at my LBS tonight and the manager showed me on of the new Ultegra 8000 11x28 cassettes. It looks like it's build to fit on a 10sp wheel. He said it only works for the 11x28 cassette and did not know if the D/A9100 cassette has the same feature.
Re: New 11sp on 10sp Wheel Option [FatandSlow] [ In reply to ]
I thought that was only the 11-34.
The point is, ladies and gentleman, that speed, for lack of a better word, is good. Speed is right, Speed works. Speed clarifies, cuts through, and captures the essence of the evolutionary spirit.
The Ultegra R8000 cassette 11-28 will only fit on an 11-speed freehub body.
The Ultegra R8000 cassette 11-34 will fit on a 10 or 11 speed freehub body.
Re: New 11sp on 10sp Wheel Option [jimatbeyond] [ In reply to ]
Thanks, Jim and Toby. I didn't see it mounted, but the 11x28 definitely was recessed on the back.
All this made me wonder if switching between an 11x25 and either the 11x28 or 34 would require a rear derailleur adjustment. But I've only seen the 11x28...
The 11-34 would require a new rear derailleur and chain.
The 11-34 is called CS-HG800-11 and fits also 10spd hubs; other scales (11-25, 11-28...) are called CS-R8000 and DON'T fit 10spd hubs
CS-HG800-11
CS-R8000
Re: New 11sp on 10sp Wheel Option [jollyroger88] [ In reply to ]
CS-HG800-11
CS-R8000
Thanks, I've read the literature.
Hi,
There is this guy in Montreal who machine 11s cassette, a lot of my customer bring his modified cassette, i've installed it and it work like a charm.
http://www.lascoconcept.com/en/11s-cassette/
If you can't fix it with you've an electrical problem dude...
Re: New 11sp on 10sp Wheel Option [velbain] [ In reply to ]
you don't need to go all the way to montreal, any local machine shop will do it for about $30 .
