sciguy wrote:
h2ofun wrote:
So I put the 175's on the bike. Pulled the seat back some. Raised the bars. Replaced the 140 stem with a 100 to pull them back to try. Need to see how the setup looks.
Dave,
If the "some" you moved the seat back is less than ~40mm then you're going to be even more scrunched up that you are in your original post where you already are scrunched up.
What saddle are you riding. Your ability to get into a comfortable aero position with appropriate anterior pelvic tilt is influenced by your saddle and how you sit on it more than just about any other variable. Once you find the correct saddle and learn how to sit on it both your nether regions and back will thank you immensely. It will make riding aero outdoors as well as on the trainer so much more comfortable. Oh and how about the fan/s you're running while on the trainer?
YMMV,
Hugh
So, need your help here since I still cannot get how do you set a saddle on a brand new person. It does not matter where I had it, IMO, and here is why.
The saddles are the normal long tri saddles.
So for my bit fit, the saddle nose is 44mm in from of the BB.
Things I read say go to 0mm.
One guy talking about his fit is 20mm back, and folks are telling him to put it at 5mm in front.
So there is only so far back the saddle will go on the rails but it would then be way behind the BB which seems to be against everything I have read?
Again, I am open to playing with anything. I have seems from 100 to 140. There is a point with my back, with this seat up, that I may have to get a stem with a larger angle since I can only bend over so far for so long.
So I see the reference for seat height, makes sense. But still have yet to hear what about seat position for a triathlon bike.
Thanks
Dave Campbell |
Facebook |
@DaveECampbell |
h2ofun@h2ofun.net Boom Nutrition code 19F4Y3 $5 off 24 pack box |
Bionic Runner |
PowerCranks |
Velotron |
Spruzzamist Lions don't lose sleep worrying about the sheep
