JasoninHalifax wrote:
OK, that wasn't clear before. now I see it.
As an illustration of the lack of controls, you have 13 runs with 150mm unlocked cranks increasing rpms, and none decreasing rpms. none of the runs with decreasing rpms were done in aerobars at all. why?
I'm not really trying to bash you in this thread. not my intent. I'm just trying to figure out what you are doing.
Why are you using HR as the dependent variable? Various people have commented on that, but have yet to get a good answer. Given the variation in HR that is in the data, how many runs are you going to need to determine if the differences are significant?
If you are dead set on using HR as a proxy for VO2 consumption, as an example of how to improve the protocol, why not run tests with a given crank length at a fixed rpm (pick one in the middle, say 70 or 80), then do 2 more runs at that crank length. one increasing rpms, one decreasing rpms. compare the HR changes from each 10 minute block to the next to remove most of the day-to-day variablity in HR, and you'll have a reasonably complete data set for each crank length in 3 rides. 15 rides you'll have 5 crank lengths done, and then you can fine tune from there....
Because I am looking for maximum efficiency using HR as the proxy for oxygen consumption. I am holding power constant and varying pedal speed (and, crank length) and watching the result. It could also be done holding HR constant and watching effect on power with varying pedal speed. In my opinion that would be much more difficult for the rider to achieve since in ergometer mode power is held constant by the machine. You are welcome to run this experiment on a subject of your choice your way and report on the results. Let us know how it goes.
"If you are dead set on using HR as a proxy for VO2 consumption, as an example of how to improve the protocol, why not run tests with a given crank length at a fixed rpm (pick one in the middle, say 70 or 80), then do 2 more runs at that crank length. one increasing rpms, one decreasing rpms. compare the HR changes from each 10 minute block to the next to remove most of the day-to-day variablity in HR, and you'll have a reasonably complete data set for each crank length in 3 rides. 15 rides you'll have 5 crank lengths done, and then you can fine tune from there.... “
Yes, I am dead set on using HR as a proxy for O2 consumption since I don’t have the ability to measure oxygen consumption directly and there is no other proxy and determining efficiency requires “knowing” oxygen consuption. In my experience and training HR is a good proxy for relative oxygen consumption in any individual, especially on any given day. I don’t like your protocol because 3 runs isn’t enough to reliably see trends unless the cadence variation is very large and fatigue is still a consideration. Further, my experience here (and with another elite) is this protocol is pretty reliable and gives the same result whether increasing or decreasing. In my experience with the other rider I would consider decreasing to be slightly better than increasing because high cadences is usually harder than lower cadences and if the rider is fatigued they will have trouble maintaining cadence. The other issue is choosing the right power to test. The other rider started at 300 watts, think he could do this, but found that too hard so dropped to 270. Even then, when fatigued he has had trouble when we pushed the cadence. Better yet would be random but that might be hard for the rider to go from 110 to 40. Anyhow, any protocol can be criticized. You are welcome to design your own, do it, then report back. If there is a better way of doing this I am all ears. But, until someone has actually done this testing I am not going to listen as to what would be a better way. This is a tough test and it takes a lot of time to get useful results.
Frank Day (
Dave Campbell |
Facebook |
@DaveECampbell |
h2ofun@h2ofun.net Boom Nutrition code 19F4Y3 $5 off 24 pack box |
Bionic Runner |
PowerCranks |
Velotron |
Spruzzamist Lions don't lose sleep worrying about the sheep
