JasoninHalifax wrote:
h2ofun wrote:
h2ofun wrote:
So after another poor bike season, being hit by Frank Day again, being off season, looking for a new bike, looking at bike fit, etc. I have started, again, to try and gather real data as to what crank length is best for me, a very tall person at 6'5. Everyone has their opinions, but as an engineer, I want numbers, and so far have not been able to find anyone who, IMO, has done some real testing.
Frank has always told me I all the test equipment needed with my Velotrons, adjustable cranks, etc.
So, you have seen my one post working on bike fit and have gotten some great inputs. But none of them talk about bike cranks since basically no one spends the time, or money, to do real testing!
So working with Frank, I have started to do some testing riding at 200 watts, changing RPM's from 110, 95, 80 and 65 after 10 minute blocks and recording HR to gather some data.
I have been riding basically the same 2 routines, one is a 120 watt spin 90 minute session, the other is an interval setup where I warm up with a step 160 to 300 watt, 1 minute steps, then a 150 watt 5 minute, 190 watt 5 minute, and then 4 230 watt, 10 minute with a 150 5 minute spin in between. I spin a 50/16 gear for 84 gear inches.
I have years of data on these ride on how far I have gone.
So last night I changed my powercranks, which are adjustable from 140 to 220mm, from my normal 200mm cranks to 175mm. Raised the seat 25mm and moved a tad forward, and rode my interval test. I usually ride around 20 miles in 90 minutes. (I rode like 27 twice which I made a mistake and changed the gear to 50/18).
So I get on to ride this morning, and after a few seconds I say time to stop, this feels weird. But, I mentally said got to do some testing. As I was riding, it started to feel a little better. What was weird is with 200's, my rpm would be around 80. But with the 175, I was doing close to 100. My speed with the 200's was around 20 mph. With the 175, it was like 23 or so. At the end I was pretty shocked to see the results. 26.85 miles. Only one data point, but in the 50/16 gear, I have never been able to spin that fast and hold it, had such a high MPH, or ridden that far.
So, now I am asking, were these results correct? If so, .....
So, will continue to post more test results as I get them. I will probably do 2 day cycles. Will do the interval work that I did today. Then tomorrow, I will ride the same setup and do Franks HR test.
Then I will shorten another 5mm, raise seat 5mm, stay at a 50/16 gear, and test again.
Seems at some point the cranks will get too short such that I would be spinning way too high of an RPM to hold. But, shall be interesting to test and see at what point I get there.
So going to put on my 175 cranks on my race bike, do a refit, and post the video on the other thread. I will then race 2 races in October with them that I have done before, and doing with some friends. So I can compare time to past, and time to my friends.
So, do these test seem fair? Has anyone else done test like these and have test results?
Jason, this first post had the protocol I am been using to start with. What is it missing? And attached is the data I have collected to do.
What is the metric you are using to evaluate the effectiveness? You are using erg mode, therefore watts is a controlled variable. Distance covered is irrelevant in erg mode. The only thing you have left is HR, which is variable from day to day anyway.
What does "5 of 10 in aerobars" mean. You need to separate the aerobar from the non-aerobar data.
Where are you evaluating what your threshold power output is with the various crank lengths.
How are you separating fatigue effects and training effects from the HR data? i.e, you are following the same RPM progression each session, which means that you are fresher at the low rpm than the high rpm all the time.
why 10 minutes at each RPM rather than do sessions at self selected RPMs?
What is your protocol for adjusting seat height and position with changing crank lengths? Is there an actual methodology, or are you just guessing? Are you moving through a range of seat heights?
Thats just off the top of my head. You have the equipment needed, but the methodology is VERY important.
Because just calling out the snowflakes. Just amazes me they nothing better in life to do than attack others.
I posted comments from Frank Day on how the test is being used. Does that not answer any of your questions on effectiveness?
5 of 10 means when I am in the 10 minute per rpm level, I situp for the first 5 minutes, and then go into the aerobars for the last 5 minutes. I then hit the next rpm ramp,
situp for 5 minutes, then get in the bars for the last 5 minutes.
As shown in the spreadsheet, I did like the first month collecting data sitting up. It is interesting to watch, when I go into the bars, my HR I can watch go up at 5 beats.
Not doing power testing now.
Fatigue efforts. I am using various things. One, the more data I collect, the more we can see trends. I also am recording when I am sick. Recording morning HR before I get out of bed. I also am recording what my long run times are, which clearly are slower after I race. So when you see my long run times are like 1:35, I am tried from racing or being sick. If I am running 1:27, I am recovered. Still recovering from my stroller turkey trot race last week, but I ran 1:29:24, with a morning HR of 54, since I am just about recovered.
Why 10 minutes per RPM step, this is the protocol Frank has given me. Will have to let him answer.
Since I had a bike fit, I am getting much closer to a better seat height. It is leg angle, etc. But, I have hit the limit of the bike seat with the shorter cranks on the Velotron, so now it is just the maximum. It should be a little higher for 150, but. Am working with Racermate to try and get some custom long bike seat posts made for me. So yes, as you can see with my recorded numbers, I have tried to change when I can. Right now at 175 cranks, around 840 is my target. So at 150, I should be at 865, but can only get to 850.
I will send a note to Frank to see if he can continue to put responses together for your great questions.
I am NOT trying to fight with anyone of what they think is right or wrong. Just trying to pass along what we are doing. I am clearly open to any logical suggestions for improvements But am sick and tired of the attacks, when they are not trying to do any type of testing with numbers.
The biggest take away I am seeing, for me, is how RPM target is impacting my HR, riding comfort, being able to push power, etc. No where have I seen anyone deal with this aspect of bike fit and riding performance.
Dave Campbell |
Facebook |
@DaveECampbell |
h2ofun@h2ofun.net Boom Nutrition code 19F4Y3 $5 off 24 pack box |
Bionic Runner |
PowerCranks |
Velotron |
Spruzzamist Lions don't lose sleep worrying about the sheep
