h2ofun [b wrote:
True, oh well, sorry for not being an expert, but have no issue admitting this. [/b]
Dave,
I'm really confused. Over the years:
1. You have often alluded to being an engineer although not what variety.
2. It appears you've been training with a Velotron since 2005 so 12 years and a Computrainer several years before that.
3. You've actively promoted both the Computrainer and Velotron all these years as great training tools and I would agree they are.
4. You don't seem to understand that when using erg mode with either one of these that cadence, speed and distance are independent of the power you're generating despite this being one of the most important sales features of erg mode. One doesn't need to be an expert to know this it's a major sales feature. Many if not most of us purchased a Computrainer specifically for this feature. So please don't hide behind "not being an expert" Just being conscious and reading the manual one time during those years should have been sufficient.
Back to testing:
As someone else mentioned:
1. Run the unit in slope mode rather than erg mode.
2. Get nicely warmed up.
3.
Riding in the aero position you race in try to ride as hard as you can for at least 20 minutes at an even sustained power. If you go out too hard you'll see a drop off before the end. If you go out too easy you'll be able to crank it up excessively near the end. In either case use the average power of the ride to inform future testing. It may take a few tries to arrive at a decent approximation of your sustainable power.
4. Record the average power of the ride as well as average heart rate.
Do the above for 200mm cranks set up as you're currently racing and then set up for 175mms on other days. You'll need to adjust the drop to the bars to be equal between the 200mm trials and 175mm trials so raise the pads 25mm as you raise the seat 25mm for the 175mm trial. I'd also slide the seat and pads back ~ 25mm for the 175mm trials. Try to be very similarly rested before these efforts.
Shift into whatever gear you seem to be most comfortable riding the high power. If you need to shift during the test do so.
What sort of fans do you have set up for cooling? If you're not using high velocity fan/s there's a problem right there.
Genetics load the gun, lifestyle pulls the trigger.
