Ai_1 wrote:
h2ofun wrote:
Ai_1 wrote:
h2ofun wrote:
imswimmer328 wrote:
I'm kinda surprised you are able to ride well at 70. That low of a cadence burns up my legs completely when I try to ride the same kind of watts as I do at 85 or so, and I'd think my physiology is more suited to gear grinding than yours. Have you tried running fast off the bike after a ride like that? Just curious how it felt.
Have done it twice now during a race. Both times my runs seemed decent, but need more data points. Plus, need to make sure my rpm was as low as I thought.
How will another test confirm the result of the last one?
Despite the regularity with which you use the word, I find it questionable whether you understand what data actually IS.
The reason to test something more than once is to check for repeatability/consistency and identify issues with the test method. I can't see how a new test can make sure your rpm for previous tests were as low as you thought unless there is some uncertainty about the means previously used for measuring your cadence.
Is there some issue with your cadence measurements? Can you explain?
In the two races I did at the end of the season, I quickly changed to 175 cranks. And for various reasons, I was not able to get my garmin going, so I was racing blind. I know I was pedaling a lot slow rpm's, but since I did not have my garmin, I cannot say exactly what I was spinning.
In my training testing, it is pretty easy since it is all working.
I now have my garmin working my 3 bikes, but since no races until next year, will have to wait on race data. And since I will probably race on cranks less than the 175's I have, will have to find cranks, and get the garmin working with them again.
This is the reason the testing I am doing on the trainer is the only way to really tell what is going on. Everything is 100% repeatable.
Okay, thanks. Glad to have that clear.
So you do not in fact have any race data regarding cadence on 175mm cranks then?
It's not a case of confirming existing data, there is no existing data.
When you say everything is 100% repeatable do you mean:
- You can repeat the same test ad nauseam with zero equipment variation.
- You can produce the same results every time you do testing.
If the former, great. Does that include fatigue, illness, room temperature, relative humidity, diet & hydration? Given that HR is being used as a critical variable, these all seem important. What's the full set of variables you're recording and analysing?
As I understand it you're attempting to optimise cadence, crank length, and position, using HR. Is that correct? What does your test matrix look like?
I used 175's in the past, and always pedaled as fast as I could but other than knowing I was in the upper 80's or low 90's, nothing as focused as I am trying to do now.
1). Yes, I can setup the hw 100% the same and the test setup, meaning, when I am testing HR, it is the exact same warmup, and 200 watts at the RPM's No wind, or stop signs or perceived effort.
2). No, I cannot produce the exact same results, which is why were are testing. Meaning, some days I am more tired, others,. And we have this going on now. I am testing on 145 cranks, but for some reason, my HR has been much higher than my previous 150 crank tests. Since I ran good off the bike yesterday, we are not sure what is going on. So, will do another test this morning. If things stay high, I guess I would put back to 150 and just get more data. Now, at some point could there be a HW change? Does the HR strap always work perfectly each day? Lots of questions which is why I am doing so many test points until we can say we have a real trend.
My test is I start a warmup for 15 minutes. start 150 watts to 300, i minutes jumps of 10 watts. Then 5 minutes of 150 watts spin. Then 200 watts fixed. Start at 50 rpm for 10 minutes. 5 minutes sitting up, 5 minutes aero. Repeat each for 10 minutes with 10 rpm jump So do 50 to 90 rpm. I finish off at 120 watts 10 minutes.
For the non fixed watts, I try to spin at 70. But when I get near the 300, I am out of the seat doing whatever, which is around 40.
Attached is the spread sheet on what we are recording. Anything missing you would suggest adding?
Dave Campbell |
Facebook |
@DaveECampbell |
h2ofun@h2ofun.net Boom Nutrition code 19F4Y3 $5 off 24 pack box |
Bionic Runner |
PowerCranks |
Velotron |
Spruzzamist Lions don't lose sleep worrying about the sheep
