Bike Shops
Coaches
Fitters
Race Calendar
Running Stores
Store
Stack & Reach
Training Log
Triathlon Clubs
We Noticed
MAIN INDEX
RULES & LEGEND
LOG IN
Slowtwitch Forums
Most aero advantage for the $
1
2
3
View All
Tri
Classifieds
Lavender
Jobs
Womens
Notices
Print Thread
jeremyb
Apr 26, 12 8:59
Post #51 of 74
(1524 views)
Re: Most aero advantage for the $ [FrostyJ]
In reply to
Quote
Reply
the slack seat tube angle of a road bike would not work with an integrated aerobar designed for steeper seat tube angles
also it would look stupid
+1lap: Lightweight Cyclocross Bikes
It's not how fast you go fast, it's how fast you go slow
jeremyb
Apr 26, 12 9:03
Post #52 of 74
(1521 views)
Re: Most aero advantage for the $ [jackmott]
In reply to
Quote
Reply
jackmott wrote:
and I think 2011 is the only time a top contender was on one of the top bikes, and he broke the course record.
kona, with the high wind variability, and tendency for bike studs to be on off brand bikes is probably the worst way possible to make any kind of comparison.
radelj44 wrote:
I love when people make comments like this.
1st place's bike split in kona:
2011: 4:24
2010: 4:31
2009: 4:37
2008: 4:37
2007: 4:37
2006: 4:18
2005: 4:25
That's 6 years of 'improvements' to bikes.
Golf is even more famous for bogus improvements. The statistical longest driver on the PGA Tour for the past 10 years has always been 315-319 yards. YET, every single year a new driver comes out and that pro says he hits the ball 10 yards further with it. If that was true, that pro would be hitting 400 yards now.
Jack, are you saying that the Cervelo P3alu would be holding the OP back? You make a good point about the hawaii times, but come on ---- those cervelo p3alu's are fast
2003 TdF Stage 19 TT
(the rainy one that Ullrich crashed on) Tyler averaged 33.5mph over 49km in the rain.
He was probably doped, but still...
(This post was
edited
by jeremyb on Apr 26, 12 9:04)
Tom A.
Apr 26, 12 9:08
Post #53 of 74
(1516 views)
Re: Most aero advantage for the $ [DarkSpeedWorks]
In reply to
Quote
Reply
DarkSpeedWorks wrote:
Tom A. wrote:
I don't think that is true...
Well, if you ever examine the guts of some modern indexed shifters, you'll see that it's not linear. Actually, if you just look at how modern indexed rear derailleurs work and know some basic geometry, it also apparent there.
If you ever do tackle this project, I'd be interested to know how you will approach doing the calculations. I am sure it is possible, but it seems like it will be hard to do it precisely.
I don't think so...I'm pretty sure the geometries of the derailleurs are designed so that a fixed amount of cable pull generates a fixed amount of jockey pulley movement, hence Shimano's "2:1" actuation ratio and SRAM's "1:1" actuation ratio.
If this wasn't the case, then I wouldn't be able to use 10sp Shimano derailleurs with 9sp shifters, or vice versa (I've done both)...and products such as the J-tek shift mate wouldn't work either.
The simple thing to confirm this would be to take apart a bar end shifter and see if the detent grooves are spaced uniformly, I guess.
jackmott
Apr 26, 12 9:11
Post #54 of 74
(1508 views)
Re: Most aero advantage for the $ [jeremyb]
In reply to
Quote
Reply
holding him back a teeny bit sure.
not a substantial amount in a triathlon though!
Meet Pro Triathlete Matty Reed at ATC - Sat May 25 - Captex!
The newest tri shop in Austin - ATC 360
Tom A.
Apr 26, 12 9:19
Post #55 of 74
(1499 views)
In reply to
Quote
Reply
Like I said earlier...that depends on the road bike, and how you put it all together ;-)
jeremyb
Apr 26, 12 9:21
Post #56 of 74
(1491 views)
Re: Most aero advantage for the $ [Tom A.]
In reply to
Quote
Reply
there's the exception, yes
FrostyJ
Apr 26, 12 9:39
Post #57 of 74
(1474 views)
In reply to
Quote
Reply
Not sure I follow. Let's sat the OP has a +6 deg 90mm stem on his road bike, then a 3T Ventus bar could work pretty well. I agree that the slack geometry of a road bike does not make a good tri bike but that is a whole different issue.
http://www.frostyjunction.com/
https://twitter.com/FrostyJunction
Record10Carbon
Apr 26, 12 9:45
Post #58 of 74
(1462 views)
In reply to
Quote
Reply
Most current systems are uniform. However, they are not on some MTN systems where the Der has the spring in the reverse. Back in the 8 / 9 speed days if I recall Suntour and Mavic had rates that were on elliptical lobes within the shifter, always buggy as piss to contend with.
Okay, that being said - as I presume you have seen, the upper wheel (OEM) from Shimano and Campy both have some side to side play on the axle. This is to accommodate slight mis-adjustments in the derailleur and let the chain have just a bit of play to properly engage with the cogset (helped in place with ramped plates, pins, groves, and what not). But, you (not the other poster) is the one who is correct. While the BRAKES are NOT linear in most applications (and a weakness of many TT style brake levers) the shifting is a constant on most of the shifting systems that we use on our bikes.
jeremyb
Apr 26, 12 9:47
Post #59 of 74
(1461 views)
In reply to
Quote
Reply
He'd be too stretched out ---- would need a forward seatpost
jeremyb
Apr 26, 12 9:51
Post #60 of 74
(1454 views)
Re: Most aero advantage for the $ [dmounts]
In reply to
Quote
Reply
Just saw you're in Fair Oaks, I'm in Sacramento, cool.
There's a 58cm P2sl that has 2 days left and is only $650 shipped
link
Throw a wheel cover on the back for $90 and an aero helmet $80 and you're set.
(This post was
edited
by jeremyb on Apr 26, 12 9:51)
BMANX
Apr 26, 12 9:53
Post #61 of 74
(1444 views)
In reply to
Quote
Reply
Or Zero Offset and the correct saddle.
I have seen people run shorter stems with aerobars and have a pretty good set up on a road bike with a zero offset post and saddle forward. Have seen the same people win tri's outright with the fastest bike.
I do not think people can make such a broad statement on ST saying a road bike can not be set up well enough to make it work with tri bars. Not saying you are but just replied to the last email.
I think Tom shows that it can be done and if you pay attention to the details it can be done.
I personally say get ride of the road frame, forks and shifters and get a tri frame and the parts required to race well.
AERO & LIGHT is RIGHT
Cervelo SLC 5980g/13.18 lbs.
(This post was
edited
by BMANX on Apr 26, 12 9:56)
odin99
Apr 26, 12 10:05
Post #62 of 74
(1419 views)
Re: Most aero advantage for the $ [Rambler]
In reply to
Quote
Reply
don't forget the machine shop-quality eye protection.
Rambler wrote:
R10C wrote:
Looks like a Scott Drop-In LF with some DuctTape doctoring....just a bit of seat post. I am guessing a Nishiki NFS Alpha or the like.
t
What helmet is that? It looks like it has a really minimal profile. The material seems to have almost a fabric type appearance. Carbon?
The_Mickstar
Apr 26, 12 10:22
Post #63 of 74
(1401 views)
In reply to
Quote
Reply
link
Yeah, but that's one of the rare steel ones!
Steve
"If you ain't first, you're last."
Ricky Bobby
Talladega Nights
dmounts
Apr 26, 12 10:30
Post #64 of 74
(1389 views)
In reply to
Quote
Reply
What about a non-integrated aerobar?.
Team Every Man Jack
https://www.facebook.com/...hp#!/teamemj?fref=ts
jeremyb
Apr 26, 12 10:30
Post #65 of 74
(1388 views)
Re: Most aero advantage for the $ [The_Mickstar]
In reply to
Quote
Reply
haha didnt catch that ----- despite the lack of verbiage, seems like a legit auction to me
jeremyb
Apr 26, 12 10:34
Post #66 of 74
(1382 views)
In reply to
Quote
Reply
in my experience, if you're using a full size clip on (Profile T2) you'll need a forward post or as Bmanx suggests a zero offset post with an Adamo saddle to get comfortable.
If you're using a shorty ITU style aero bar you might be able to feel comfortable with the seat slammed forward ---- but then you're forearms are going to hurt like hell because your radius and ulna arent used to supporting your upper body weight.
I have used a Profile T2 on a Cannondale road bike with a zero offset post and was not comfortable ---- way too stretched out.
The_Mickstar
Apr 26, 12 10:34
Post #67 of 74
(1382 views)
In reply to
Quote
Reply
I agree. If I had the money, I'd be tempted to upgrade from my Dual. It's my size.
Steve
Ricky Bobby
Talladega Nights
Guddis
Apr 26, 12 10:38
Post #68 of 74
(1376 views)
In reply to
Quote
Reply
Swim cap over your road helmet, saves you 0,4mph
valdlaw
Apr 26, 12 12:42
Post #69 of 74
(1333 views)
In reply to
Quote
Reply
Tom that looks sweet! I have a Venge but only becuse Im with a Specialized shop. I see you have the Adamo Road on there. I've recently put one on my ShivTT and I'm tring to set it up so that I'm comfortable. I cant trll form the photo do you have your rails totall level with the ground or do you have them very slightly angled downward? I feel like unless I point the rails slightly downward the prongs jam into my rear. However if you angle it downward it places too much stress on my upper body and feels like Im falling forward. Am I doing something wrong or missing something? Thanks!
Oh and sorry to ask didn't mean to hijack the thread :)
(This post was
edited
by valdlaw on Apr 26, 12 13:05)
Tom A.
Apr 26, 12 15:01
Post #70 of 74
(1291 views)
Re: Most aero advantage for the $ [valdlaw]
In reply to
Quote
Reply
I actually find that "rails level" is a good starting point...I think I'm actually at rails slightly above horizontal right now.
mfrassica
Apr 27, 12 11:36
Post #71 of 74
(1182 views)
In reply to
Quote
Reply
Could not agree with your statement more. Ya, carbon is cool if you have a money burning a hole in your pocket. However there are a lot of nice used bikes out there that is plenty fast enough. The OP will also tend to have extra money to spend on aero-helmet or wheels...
I bought used myself, P3-SL (just over 1K) and love it. I did have the money to spend if I wanted to, but practically I could not justify the aero savings of say a P4 over a P3-SL. A lot of the wind tunnel data is set as something like 30 mph. Most of us are not at this speed for any appreciable time, aero benefits (between any given bike) will start to decrease (exponentially) as velocity decreases. However, by all means go as aero as possible. $ for $, go used equipment.
vibrolux
Apr 27, 12 11:43
Post #72 of 74
(1171 views)
In reply to
Quote
Reply
Do a search on my username, "vibrolux" and look at the thread where I asked about the Adamo versus the Cobb V-Flow Plus saddles. Some good responses but pay particular attention to Rappster's response.
I had the same problem as you and scrapped the Adamo for the Cobb. With the saddle set to be comfortable on my ass, I felt like I was launching off the front of the bike and my shoulders/upper back hurt after like 1 mile in the aero bars.
Reading some of the responses may help you.
valdlaw
Apr 27, 12 15:48
Post #73 of 74
(1087 views)
Re: Most aero advantage for the $ [vibrolux]
In reply to
Quote
Reply
Much appreciated.
Tom A.
Apr 29, 12 16:17
Post #74 of 74
(993 views)
In reply to
Quote
Reply
I happened to have a chance to pull off the rear TT shifter lever for a SRAM setup and took a pic of the "working bits". Those teeth look to be fairly uniform in spacing, no? :-)
1
2
3
View All
Print Thread
this forum
this category
all forums
All words
Any words
Whole Phrase
Market Influence
What influences your swim/bike/run product buying decisions most? The use of products by, or comments made by or in:
Pro cyclists?
Pro triathletes?
My non-Slowtwitcher friends?
Forum members and other Slowtwitchers?
Slowtwitch tech articles and forum moderators?
Other magazines?
Manufacturers?
My LBS?
Ratings/comments on other websites?
Other
