So my project where everything seems to go wrong has hit another hiccup...
I have the front and rear wheels laced (was able to correct spoke lengths) and tensioned
First issue is the rear wheel NDS spokes, the tension is really low on these spokes with proper dishing. I set the DS spokes at 14 on the TM-1 spoke gauge, at this tension the NDS spokes end up @ 7. 50% less then drive side, not really ideal but the fault of the powertap hub geometry.
Here is where it gets weird. When the tire is put on and pumped up. The tension drops off the chart. The DS spokes loose tension to 10 on the meter, and the NDS drops to 2-3. The wheel is obviously soft at this tension, but it stays true. Put the tire off and vola, back to the original tension. I measured a few of my other wheels at home and at most they lost 1 on the meter, often losing nothing.
What the heck do I do now? If I tension the wheel with the tire on I will end up way over the recommended tension of the flo rim when the tire is off (Not something that happens). But I can not ride it like it is.
I google searched this and got too many mixed answers. I trust the brains on this site more.
According to Flo owners manual I should have max. 110kgf of DS and front spokes and 50-90kgf on the NDS. At 14 I was supposedly at 118kgf, and @ 7 I was at 62kgf.
