Well, I promised I'd let you in on some of the riders' aero improvements, with their permission. We had the good fortune to have Frank Mizerski, Retul Master Certified fitter at
Racer Sportif, to help us out. Frank made sure that I never stretched Marc outside of what was biomechanically sound. Thanks, Frank!
We also had Slowtwitch's own,
marcag, in for testing on one of the days. Marc's one of those techie Slowtwitchers who understands the equations and has been following Slowtwitch's "best aero practices guide" for quite a while. I'm sure he has a direct hotline to Jack Mott's home phone or something. :-)
Marc was a good enough sport to allow me to publish his testing. There was a bit more testing and fitting than what I describe here, but I wanted to give you the general trend. The whole thing took 3 hours, and was done in tandem with another rider. While one tested, the other got wrenched on the apron of the track. 60 minutes per rider is good enough to get some results, but we recommend 90 minutes per rider for tandem testing.
We started out with a baseline run of 0.294 m^2 which, given Marc's position and equipment, didn't make sense. But a close inspection of his helmet revealed that there were huge gaps between his face and his Giro Advantage 2. The straps were very loose and overlapping the outside surface of his helmet. You could almost hear the helmet whistle by as Marc raced. I remember telling him, "C'mon, Marc, that helmet is a frickin' mess. Clean that up!" Marc's very next run was a 0.276 m^2. Perhaps a bit of it was due to some slightly smoother riding, but this was the start of his aero improvement.
Lesson 1: Clean up your helmet straps and choose the right size helmet. The next set of laps tried to get him more reach, but this didn't help. It was at this point that I noticed that his basebar was angled up slightly, at probably a 15deg angle of attack. So we levelled the bars, with no significant change to his CdA.
The next attempt was to try to make Marc's arms more parallel to one another, rather than having that awkward triangle shape. The armpads were moved 5mm to each side, and the saddle was moved forward to allow Marc to reach his grips a bit better. Result: 0.264 m^2.
Lesson 2: When it doesn't increase your frontal area, try to keep your forearms parallel to one another. The frontal projection of your arms should remain within the outline of the rest of your body (hips, legs, etc...). After a few minor tweaks, we were all pretty happy with the comfort and aero-ness of Marc's positioning, so we turned our attention to suits. Marc started with an Orca RS1 one-piece, with lots of shoulder showing. So we tried a quick change, putting the LG Course Tri Top directly over the DeSoto Forza ITU suit, with disappointing results. A complete change, with cycling shorts and the M2 Top gave us an impressive 0.256 m^2.
Lesson 3: Skin is slow! Translation: Cover your vertical cylinders.
Finally, we tried a shrug test to see if the position and equipment could be improved by posture. Sure enough, a gentle shrug gave Marc an 1-lap CdA of 0.242 m^2. Obviously, this is not something that he could hold for an entire Ironman, but it could certainly come in handy in a strong, momentary head wind. We usually try it to see if repositioning the rider might help the shrug be more comfortable and sustainable.
All in all, not a bad day's work for Marc. He rode very consistently, and his cheerful manner made the testing very pleasant.
Thanks, Marc, for testing with us!
AndyF
bike geek
