here is what came out of the box:
i don't know if the cable unintentionally fell out of the coupler or if it's designed to come this way and then i shorten to suit.
the cable appears to have a compression insert already in it. mind, i'm entirely naive to bike hydraulics (i suspect i'm about to learn some), but in copper compression fittings (where i am not naive) it seems like the same sort of dynamic is in play.
if so, then i would stick the cable (if it's the correct length) into the fitting, screw down the fitting until it's tight and then whammo i'm good. except that i may then need to bleed the line.
yes?
Dan Empfield
aka Slowman
yes?
Dan Empfield
aka Slowman
