JackStraw13 wrote:
Has anyone had their Zipp 10sp hub machined so they can run 11sp? How is it holding up? I am looking at getting Etap for my 08 P3C and don't want to spring for a new wheel. Would rather go this route than the other options. Race only wheel so won't get a ton of use.
Here are 2 additional options for you to consider:
1: There's an eBay seller that sells free hubs that accommodate a Shimano 11s cassette. They are, of course, not officially approved by Zipp. My suspicion is that while it will work almost all of the time, there might be a combination of frame + smallest cog that does not work, so Zipp probably did not want to undertake a project like this. (For those with sinister thoughts, lack of availability of a conversion freehub directly from Zipp would mean that some riders would feel compelled to buy a completely new rear wheel.)
I purchased one of these and used it without problem and know a number of other people who have done the same.
If memory serves, they are ~$100 and arrive pretty quickly from Taiwan.
2: Buy a Campy freehub, which allows one to use a Campy 11s cassette, and run that. The Campy 11s cassette spacing is perfectly compatible with Shimano 11s, but Campy cassettes are typically a little heavier for a given price or a little more expensive for one of comparable weight to the Shimano.
I've also done this, and it shifts perfectly. If you swap between this wheel and one with native Shimano 11s, you might find you have to adjust the RD a hair when you make the switch; if you are not swapping wheels, there are no issues.
