I recently bought my first tri bike. I still plan to ride my road bike semi-regularly (couple times per month at the most).
I have a Powertap SL+ wheel. Both bikes are 10sp. My plan was to buy a second 10sp freehub to put my road cassette on. Then I should be able to swap the freehub body whenever I want to change bikes. Seems pretty simple to me and allows for swapping the wheel to be totally quick and painless. With two little kids, time is precious...
My LBS strongly recommended that I not go this route. He said it would be risky to swap the freehubs and that they're not meant to be removed. I was talking to him on the phone (I really just called to inquire about 10sp freehub availability) but from what I gathered he was concerned that the pawls (?) could be damaged. He was pretty adamant that changing the cassettes out would be much better.
This seems like BS to me. Thoughts? My thought is that he's either just wrong, or he's right that it can damage the pawls but the risk is so small that it should not be a concern.
Further question: I intend to upgrade my 10sp tri bike to 11sp Ultegra di2 in the next 6 months. Does it make sense to buy an 11sp freehub and mate my 10sp tri cassette to it? It seems like this should be doable with a spacer and (possibly?) a derailleur adjustment. Then when I upgrade I can put the new cassette on the 11sp freehub and leave the 10sp road cassette on my current 10sp freehub. Seems like this makes more sense if it will work because then I won't have an extra 10sp freehub that I don't need after I upgrade.
One further: if I ever have to upgrade my 2nd gen PT hub to a 3rd gen, will this cause me any problems?
