So with the purchase of the zipp wheels (404 front and 808 back) I also purchased 4 zipp tubes with the zipp extender. My questions:
1. When you race, do you pre attach the extender to the tube for a fast change or attach ext after flatting?
2. If the extender is pre-attached, how many tubes do you normally carry for a race. Without the extender I can squeeze in two tubes in my saddle bad, with the ext, only one?
3. How many tubes should I carry on the bike for my first full IM (IMMT)?
4. Are zipp tubes good? As I was rolling the tube to place in my saddle bag it kind of had a twist in it which I never noticed on other tubes. Two of the four tubes I bought seem to have this twist. So if you position the tube in my hand and using my fingers slide the tube while it is flat, all around, by the time I make a full rotation the tube is facing the opposite way, ie if I started with the valve facing down, when I finish going around, the valve is facing up. Is this normal? When I put some air in it it seems fine but my concern is when I place it in the wheel it may twist and fail prematurely. Again, is this normal or should I return the tubes?
Thanks
Thanks
