holograham wrote:
I ask bc this is my first ironman. And I have not done a 112 mile bike after an OW swim in high 40's temp. There are definitely new factors. I am not even sure how changing works in T1 ... the athlete guide just talks about your bags not the actual logistics. Lastly, shedding layers seems like a way to go but not sure if you are allowed to at the aid stations (and likely wont get them back). I get these are noob questions but just trying to make it to the finish line in one piece.
You drop your T1 and T2 bags the evening before the race. You drop your bike and run special needs the morning right before the race. You show up with what you need for the swim and your dry bag race morning. When you change for the swim, you put all your stuff in the dry bag and hand it in where they tell you to. (After the race, this will be the bag you get to change into warm clothes.) Then you walk to the swim start with only what you need for the swim.
After the swim you run out of the water, let a wetsuit puller remove your wetsuit, or do it yourself. You run past the T1 bags, grab yours or maybe have a volunteer hand it to you. You run into a changing tent. There will be more volunteers to help you, if it is not too crowded. You can change into your riding gear, or if you are wearing your riding gear under your wetsuit, you grab you helmet and stuff and run out. You may have to stuff everything from the swim into you T1 bag, or a volunteer may do that for you. You get on your bike and go.
About halfway through the bike course you will have an opportunity to grab your special needs bag, if you want. I usually put nutrition in this. You will never see this bag again if you choose not to stop for it. You cannot drop stuff off, unless you toss it in the trash.
From T2, bike to run, is similar to T1. You will hand your bike to a volunteer at the dismount line, run past the T2 bags, grab yours, or have a volunteer hand it to you. You change from bike to run clothes. Or drop off your helmet and shoes and grab your running shoes and whatever else you want from the bag. Again, a volunteer may be stuffing everything into your bag for you, or you may need to do it. I have had volunteers dump out my bags, help me with what I have needed, and then tell me to go while they put all my bike gear into my bag. I have also had to do this myself.
Mid run, you get your run special needs bag. Again, put whatever you want into this. I may have nutrition. I have also put a throw away long sleeve shirt in sometimes, just in case I am running late and it gets cold. You will never see this bag again. If you do not pick it up, it vanishes into the void.
When you finish, you can grab you dry bag and change. You get your T1 and T2 bags back. Hopefully your bike- usually a bracelet checkout from transition. Again, special needs bags are gone.
I will probably wear a bike kit with knickers and arm warmers. And socks. If it gets warm, I just pull down the arm warmers until they are only on my wrists. I can always trash them at an aid station if I really need to. Some people use old tube socks as arm warmers because they know they are going to toss them. Anything you peel off during the race is gone unless you hand it to family. I will probably take a page from cyclists and put some paper or plastic under my jersey to block the wind and keep me a bit warmer during the first part of the course. I am still debating how to handle the run.
"Remember: a bicycle is an elegant and efficient tool designed for seeking out and defeating people who aren't as good as you."
--BikeSnobNYC
