I bought some of the pink Vittoria Latex Tubes for my FLO 45's. The valve's are just slightly too short to allow for my pump to grab. I bought some "valve extenders" from a LBS, but those have internal threads that don't match up correctly to the threads on the tube. I saw on a Youtube video that I need "internal extenders". Where do I find these? What are you guys using?
Re: Internal Valve Extenders (or core) for Vittoria Latex Tubes [cbr shadow]
Re: Internal Valve Extenders (or core) for Vittoria Latex Tubes [stevej]
Could you give me a link? I keep finding the external type everywhere.
Silca makes two kinds - one for removable core valve stems and a different one for non-removable.
All the Vittoria latex tubes I've had have removable valve cores, so I've used the corresponding Silca extenders.
I've tried a couple of other valve extender arrangements and the Silca removable core ones are my favorite - most reliable and least hassle - so far.
Re: Internal Valve Extenders (or core) for Vittoria Latex Tubes [alathIN]
Thanks guys, I ordered the ones in the link above.
The Conti extenders work fine with Vittoria Latex tubes.
https://www.amazon.com/gp/product/B005UGC2EG/ref=oh_aui_search_detailpage?ie=UTF8&th=1&psc=1
Re: Internal Valve Extenders (or core) for Vittoria Latex Tubes [jsk]
jsk wrote:
The Conti extenders work fine with Vittoria Latex tubes. https://www.amazon.com/gp/product/B005UGC2EG/ref=oh_aui_search_detailpage?ie=UTF8&th=1&psc=1
Guess I should have waited and saved $23!
I'm clearly a bit biased, but you can sleep knowing that the SILCA extenders weight 1/2 as much and use a barrel seal instead of a straight seal which guarantees they will seal across the entire range of valve tolerance and then some.. :-)
Josh
http://www.SILCA.cc
Josh
http://www.SILCA.cc
