Improving running economy
I recently completed a running VO2 max test as part of a friend's PhD project and it gave me some very interesting results.
For reference, I come from a swimming background but I would call myself an above-average runner with a 34:02 10km and a 16:30 5km. However, compared to the guys I race against, running is my weakest discipline.
Now onto the test.
I scored 70.7 ml/min/kg as my VO2max, a pretty good score. But then, after some results processing, my running economy came out as an abysmal 253 ml/kg/km (170 is considered excellent, 210 is considered poor).
The test was done straight after a fairly hard swim and I'm about a quarter of the way through a 100runs/100days block.
So my main question is, how do I improve economy? My technique is fairly good, midfoot strike under my centre of mass, good extension behind, no dropping of hips, minimal upper body movement. Is it trainable? Genetic? Technique based?
Thanks for any advice.
Re: Improving running economy [parkstar] [ In reply to ]
Things that have strong evidence supporting improvement of running economy:
1. lighter shoes
2. running more, running harder
3. plyometrics
Things that evidence suggest does not help, usually:
1. trying to consciously change your technique
powercranks
Dave Campbell | Facebook | @DaveECampbell | h2ofun@h2ofun.net
Boom Nutrition code 19F4Y3 $5 off 24 pack box | Bionic Runner | PowerCranks | Velotron | Spruzzamist
Lions don't lose sleep worrying about the sheep
Re: Improving running economy [h2ofun] [ In reply to ]
whoa there I'm not trying to start a riot...
:o)
They run faster in an open run race? Or they run faster off the bike in a multisport race? Based on what you wrote I am assuming you mean off the bike.
How are your 5K/10K times off the bike vs open run races?
Rodney
TrainingPeaks | Altra Running | RAD Roller
http://www.goinglong.ca
Re: Improving running economy [rbuike] [ In reply to ]
faster in an open race
I'm at a loss. Your technique sounds on-the-money, so where is the gap?
Did you get any details on the remaining issues that need to be fixed?
Those are awesome results! And I think you should be INCREDIBLY excited by the bad economy. That improves easily over time. I'd bet you have a sub-31 10k in you.
On to the list!
1. The lowest hanging fruit: strides. Lots of strides. After your normal easy runs, do 4-6 x 20 second strides, starting relaxed, building into it, and getting close to top speed by the end. Every pro/elite I know (especially the non-natural runners) do lots of strides. Hill sprints are a good variation on the same theme! Also short, just 15 seconds or so, focusing on power at first and working to high turnover.
2. Hill intervals once every week or 10 days. Something super simple like 20 min warm-up, 10 x 60 second hills moderately hard, 20 min cool-down.
3. Form: Aim to keep your cadence above 175 at all times.When running fast, imagine you are trying to hold a quarter in your buttcheeks.
4-infinity. Run lots. You've got that going with the 100/100.
Hope this helps! You have a massive well of talent to work from, so 4 alone will probably lead to amazing results.
David Roche
Some Work, All Play podcast: https://podcasts.apple.com/...ll-play/id1521532868
Coaching: https://swaprunning.com/
I would add a couple of things to what jackmott said.
1. Hill running
2. Sprint training (which may be what he meant by faster running)
Re: Improving running economy [eswinner] [ In reply to ]
Running economy is affected by many things that are not related to technique.
Re: Improving running economy [DaveRoche] [ In reply to ]
Thank you, that's really helpful and very encouraging
Re: Improving running economy [jackmott] [ In reply to ]
And just because someone describes something on the internet, doesn't mean much.
Here's the thing.
You're a good, but still average athlete. (ie. Faster than many, but sub-elite)
We have elite performance with high VO2 max and High economy.
We have terrible performance with low VO2max and Low Economy
The rest of us? We probably have one or the other, but not both. That makes us average. (Personally, I'm about 71ml/kg/min with a 5.3L/min absolute on the bike and probably can't break 20 in a 5k. Running-wise I'm a 400m hurdles through and through).
With that said: Plyometrics and weight lifting are probably your best bets for increasing economy.
I talk a lot - Give it a listen: http://www.fasttalklabs.com/category/fast-talk
I also give Training Advice via http://www.ForeverEndurance.com
The above poster has eschewed traditional employment and is currently undertaking the ill-conceived task of launching his own hardgoods company. Statements are not made on behalf of nor reflective of anything in any manner... unless they're good, then they count.
http://www.AGNCYINNOVATION.com
Re: Improving running economy [xtrpickels] [ In reply to ]
Here's the thing.
Those are probably the last 2 of a long list of element that could help him
run more is the first element.......
Jonathan Caron / Professional Coach / ironman champions / age group world champions
Jonnyo Coaching
Instargram
You're welcome! To follow up on some other things stated: with your swim background, I really don't think you'll get much benefit from strength exercises (weight lifting and plyometrics). I had a similar build and switch to running--it's all about becoming a "runner," which entails the necessary loss of bulk and loss of non-specific strength. Given your background, my guess is that strength work will just reinforce some areas where you are already solid at the expense of the areas you need to work on.
That made no sense, but I was trying to find a diplomatic way of saying weightlifting and jumping and stuff will not help you get faster at this point :)
David Roche
xtrpickels wrote:
Here's the thing.
Slowtwitch: where all the athletes are below average.
I can speak from experience here - saw a massive jump in performance in a single year. One thing: don't think in terms of "economy" like you would "form". Think of it as exercising the transmission at a high level of work, and some of the gains will be attributed to different mechanics (if you did before/after videos, it would look different), but most will be from improved utilization of movement timing (video would look the same, but the time vs. force plot for your stride would change, aka, you learn when to push really hard and when to totally relax). But none, exactly zero of this can be done actively while you are racing or running race-paced workouts. Just try to stay relaxed for those. The best workouts for transmission work:
1) 30 second hills, with a fast (20-30 sec) jog down. start with 3 sets of 5, building to 3 sets of 10. It is an excellent V02 workout as well. Great for early season as you get high-intensity sitmilus without the pounding from track work.
2) Longer, sustained uphill runs at or just above LT (20-40 min), with the focus on completion of each stride. You might run a few % slower than if you ran with a "clipped" stride, but that does not matter.
3) The best and most important - "motor paced" 10 mile ( or ~50-60 min) tempo runs. Find a person who is faster than you (or will bike at a constant speed), and after a good warmup, do the 10 miles just under LT, with the last 5-6 with slightly loaded legs. Have your pacer keep it perfectly steady and you just sit in and shut your brain off and coast and think about.. nothing. Just turn off and get into the rhythm. As you tire (but the pace stays steady), your body will figure out the most efficient movement patterns when fatigued. This also works on a treadmill but is pretty horrible. Learning how to run fast with tired legs is huge.
4) on recovery days, do strides intermixed with the easy run. Say every 6 minutes of the run for a 60 min run, 15 sec burst, then back to recovery pace. This also helps to keep the recovery run from turning into a slow tempo run, the bursts give yu a chance to get the zip out.
One of the top XC programs in the country uses this method to take HS 10:30 2-milers (so pretty mediorcre talent) and turn them into low 14:00 5k guys or sub 3:50 1500 guys.
1. lighter shoes
3. plyometrics
Excellent answer.
Also in the first group would probably be "stop stretching".
Re: Improving running economy [Andrew Coggan] [ In reply to ]
I'm learning lots on Slowtwitch today. Why stop stretching Andrew? Thanks
Re: Improving running economy [goldentech] [ In reply to ]
I love these threads. Reminds me just how much faster I can get by:
  • running more
  • running faster
/kj
http://kjmcawesome.tumblr.com/
Re: Improving running economy [kjmcawesome] [ In reply to ]
if you want to run faster
run faster
lol
  • running more
  • running faster
I think the hill work is something so many miss, and avoid. I run hills, 1000 feet of climbing, 3 days a week in my 90 minute LSD runs. And boy can I feel it if I take
a few days off! Hills are my best friend. Zero track work ever.
I just checked my weekly 90 minute route - 1800 ft of climbing for me on that one (and yes, you def feel it!)
I still think there's a need for speedwork - the leg strength helps some, but on the downhills & flats you want to have developed the fast leg turnover required to keep a fast pace on those sections. I've been lagging on those in races lately, getting passed almost exclusively on the downhills.
As an aside as well, you get can awesome hillwork galore on a treadmill. No downhills!
Re: Improving running economy [lightheir] [ In reply to ]
I believe the powercranks help me with leg strength for downhills without the injury risk of doing fast in training. I know when I go down the hill at the end of wildflower, I can just fly.
Wow, 1800 feet in a 90 minute route, killer. I do 3000 feet of hills per week.
I guess I have just been lucky to be able to run fast with zero speedwork.
I do like running my 10 minute bricks on my treadmill after my bike trainer at 6:30 pace, so maybe that is some speed work since it kicks my butt.
