This is probably thread #1000 on the usefullness of power meters, but since it seems I'm the only one still not being convinced, I warm up the discussion again.
I know my heartrate (HR) zones for the different trainings and races, eg sweetspot, long slow rides, IM speed etc.
Only for shorter intervals, e.g. 5*5 minutes on full speed, HR doesn't work, here I use perceived effort (PE).
(Of course for aerotests a PM is compulsory, but I would like to blend that out in this thread)
So a power meter wouldn't change anything in training or races, other that I would stick to a Wattage instead of to a HR??
Using a PM would even have two disadvantages compared to HR:
1) the HR for the different trainingzones does not change a lot during the season, whereas the Wattage does (it should increase during the season, otherwise you do something wrong).
2) The big advantage always put forward for PM instead of HR, is that HR is insecure because of shape of the day, temperature etc. I see this oppositely, if it is warmer or if your shape of the day is less good than you should go a bit slower, as your HR shows, and if you try to hold a certain wattage you might go to fast for the type of training or race you want to do that day.
Convince me I'm wrong.
