Does anyone have experience removing epoxy from a carbon frame? My LBS replaced by bottom bracket but there is epoxy residue on the frame and I can't get it off. Thanks
Re: How to Remove Epoxy from a Carbon Frame [Mfree]
Why was epoxy used?
I would suspect that it is primer or threadlocker.
Re: How to Remove Epoxy from a Carbon Frame [lyrrad]
I used epoxy as just a general term. Very well could be what you mentioned below. I've tried heating it, rubbing alcohol, and even WD 40 but no luck
Mfree wrote:
Does anyone have experience removing epoxy from a carbon frame? My LBS replaced by bottom bracket but there is epoxy residue on the frame and I can't get it off. ThanksI'm pretty sure it won't be epoxy because if you use epoxy glue to put a bottom bracket in your frame it's there to stay forever and if your BB needs to be replaced, you won't be able to get it out anymore.
Which color is the residue? Pic might help.
I'd take it back to your LBS and have them fix it. I sure hope they didn't epoxy that bb in.
Hope is eternal...and so is an epoxied BB.
