Home gym setup advice - road to recovery from illness
I started last season as a Cat 3 racer here in Ireland having been promoted at tail-end of prior season. Started season well and was feeling good about prospects and then came to a halt in May. Got diagnosed with sarcoidosis, relatively rare inflammatory disease, in September which explains that. Have been dealing with the condition, and pneumonia it brought on, since then and have been doing well to manage without ongoing steroids.
I'm at the point where I'm able to now start some exercise - after 5mths off, it'll be a long and gradual road, and I've been told I won't be allowed go over 80% intensity for likely another year or more. It's driving me nuts, though at least I have Zwift for when I'm up to it. I'd really like to get a home gym setup in my back yard to work on leg strength - while I can't do maximal reps much, I figure starting a routine of some max 80% intensity leg strength workouts now will have good benefit over the course of a year and will give added power for when I do get back into the swing of things fully.
A friend I was roughly on par with went from 3.8W/Kg to 5.02W/Kg over the winter, and puts it down to weight sessions in the gym and increasing cadence. I'm very, very time crunched, so gym visits are not an option. Don't have space in house or shed for gym gear right now, will do when I move house in next 6-9mths, but for now wanted to get advice on what equipment (budget of about 500euro) I could get to put outdoors in my back yard that will withstand rain etc., and what exercises I should focus on. All exercise routines I will embark on will be agreed with my specialist in advance, so please don't worry about that side, I'm looking at a long-term, gradual approach and want to see what groundwork I can lay now that'll help over a year or more.
Re: Home gym setup advice - road to recovery from illness [OhPinchy] [ In reply to ]
I can't really provide much help in terms of what sort of gym equipment you'll be able to source inexpensively but one suggestion I do have is that if you're going to do squats consider finding some steel chains to use in addition to any weight plates. They provide maximum resistance at the top and minimal resistance at the bottom as their length decreases as you go down into the squat and increases as you stand back up.
A TRX system is pretty inexpensive and doesn't take up a lot of space. All you need is a place to attach it and you can bring it inside when you aren't using it.
You don't need weights to do some serious leg strengthening exercises. Do single leg pistol squats. Add a little weight (it actually makes it easier to counterbalance) once you master your own bodyweight.
Start in a doorway to balance/aid or do 1/2 squats on a bench to start out. Then graduate to full squats as you get stronger. Some core exercises sprinkled in there would be good too.
