cshowe80 wrote:
I'll chime in here since I have a pretty well oiled setup for myself. I use the following
Garmin Forerunner 920XT
Garmin Edge 510
Garmin HRM-RUN
Garmin Foot Pod
PowerTap G3 Hub
Withings Wi-Fi Scale
CompuTrainer Pro
Training Peaks Premium
Garmin Connect
Strava
MyFitnessPal
Software: You can connect TP and Strava to Garmin Connect to auto Sync. This Syncs the workouts so I just need to edit and add comments and session details. One less step to do but those details have to manually be added to the 3 platforms if you care to maintain true synchronized data across all 3. I just fill the details into one and then copy & Paste to the other two. Typically TP is the central place since my workout was planned and outlined in there.
Swimming: I use the Forerunner 920XT for indoor and outdoor workouts. It tracks all the valuable metrics I need to hit my KPIs for each session. When I am done swimming it auto uploads to Garmin Connect which syncs to Strava and Training Peaks.
Biking: I use my Edge 510 with the ANT+ Relay option in TP so that I'm getting all the data I want and removing the need to manually download the file from TR to Upload to Garmin Connect. The Garmin captures some metrics TR is missing like temperature, elevation, and a few others. My Powertap/Computrainer takes care of the cadence and power output removing the need for a secondary sensor. I also use my HRM paired to the Edge 510 to get those additional details rather than the proprietary CompuTrainer HRM.
Running: I use the Forerunner 920XT for all my running paired with the HRM-RUN to get the maximum amount of metrics to use. Also for indoor running on the treadmill I ensure accuracy with the foot pod rather than the internal accelerometer. Runs are automatically synced to Garmin Connect which then pushes them to the other two.
Recovery: I use the Forerunner 920XT with a custom made "Activity" to track this as well. I most use it to track duration while foam rolling, stretching. Surprisingly the interval function has proved to be of the most value when I need to focus on holding a tough stretch and ignore clock watching. It beeps I switch poses/stretch and keep my focus on that not on how long I've got left to go. It also tracks my sleeping and "other" activities via step tracking. I also use MyFitnessPal to track all my food and water intake which then syncs with TP/GC. MyFitnessPal also takes the weight measurements from my Withings Scale and auto updates my weight in Myfitnesspal however this does not sync to TP or GC as of yet.
I'm sure others have their own methods but for me this setup means the lowest level of manual work I can get away with still keeping all 3 platforms active and accurate. This gives me a great overview of my entire training and allows others to quickly see what data they need to to help me further tailor my training to get the best results possible. Hope these details help you a bit. Keep plugging away in the pool and you'll get it soon enough!!
Thanks for the input CSH...While I was hoping to utilize the devices and software I currently have, I'm sure open to looking at a more automated system. I've been having lots of issues by way of drop outs and inaccurate readings from the TickR Run so it's time with me is limited. I was thinking of going with the garmin HRM/Pod you mention in hopes of improved accuracy. That said, the memory that of the TickR X would be great and remove the need to lug the iphone around which I currently have no way of doing once the cold is gone and I deep six the clothing (warmed up to -2C yesterday so It's close).
As for the swim, well....let's call it a work in progress...I'm hitting the pool a min of 3 times a week and will move that to 4 next...I'm not doing anything more than just freestyle and my only other requirement (other than getting there 4x's a week) is swimming for 45-50 mins. I don't count laps yet, but will start that soon as I'd like to improve on my horrible time last year as well as move up to Oly length so I've go my work cut out.
